    [BATCH] Scrape your roms on your PC - fastscraper
    Community projects
    multiconsole scraper fastscraper
    37
    221
    286011
      paradadf Staff @airart last edited by paradadf
      @airart are you running the batch as administrator? If so, don't do it.
      What was that about a pc and a mac? I didn't understand.
      FYI there is a new version for macOS:
      https://forum.recalbox.com/topic/5745/bash-scrape-your-roms-on-macos-and-linux-fastscraper
      airart 1 Reply Last reply Reply Quote 0
      • airart
        airart @paradadf last edited by
        @paradadf said in [BATCH] Scrape your roms on your PC - fastscraper:
        I 'm non running as administrator
        I said that on mac not think there was the possibility
          @airart are you trying to append an existing gamelist?
          • airart
            I asked him to create a new one
            • airart
              airart @airart last edited by
              @airart said in [BATCH] Scrape your roms on your PC - fastscraper:
              The problem may be that they are not connected to recalbox?
                @airart no, I never scrape over the network, but on my pc. I have no idea what is going on, but I would try to erase the gamelist.xml and download_images folder and scrape again. I still believe you are executing the batch with administrator privilege and thus the error. Look at the title bar... it says "Amministratore".
                • airart
                  I know , but I do not understand how to do, I did not set the administrative mode
                  • rsn8887
                    rsn8887 last edited by paradadf
                    Worked two days ago, now broken:
                    ERR: error processing H:\EmuRoms\Recalbox\recalbox\roms\gba\2 Game Pack! - Matchbox Missions - Emergency Response + Air, Land and Sea Rescue (USA).zip: 504 from $s%!(EXTRA string=http://mirror.screenscraper.fr/api/mediaJeu.php?crc=&devid=&devpassword=&jeuid=83014&maxwidth=400&md5=&media=ss&mediaformat=png&sha1=&softname=sselph%2Fscraper&systemeid=12)
                    panic: runtime error: invalid memory address or nil pointer dereference
                    [signal 0xc0000005 code=0x0 addr=0x14 pc=0x408fe7]
                    goroutine 31 [running]:
                    panic(0x7e9580, 0x1137e030)
                    /usr/local/go/src/runtime/panic.go:500 +0x331
                    main.crawlROMs.func2(0x120b29d0, 0x11dcb540, 0x0, 0x120b29c0, 0x1287e0c0, 0x1287e040)
                    /home/sselph/go/src/github.com/sselph/scraper/scraper.go:295 +0x527
                    created by main.crawlROMs
                    /home/sselph/go/src/github.com/sselph/scraper/scraper.go:328 +0xbd7
                      paradadf Staff @rsn8887 last edited by paradadf
                      @rsn8887 I read on the UXS thread that gba was having problems the last couple of days... Do you still have this problem? Does it happen with any system or only gba?
                      I've also encounter some single roms which had wrong data on SS and thus "broke" the scraping process.
                      So please,
                      • try to scrape gba again
                      • try scraping any other system to see if you still get an error
                      • if other systems work and if the problematic rom is one of the first ones, try removing it. (And give me the name)
                      I'n not on my computer right now, so I can't test.
                      Update: This is what I had read
                      https://github.com/Universal-Rom-Tools/Universal-XML-Scraper/issues/142
                      • rsn8887
                        @paradadf
                        Other systems show the same problem, but some don't. For example gb scraped fine completely through all roms, but gba and n64 didn't. I tried to remove a few roms where the error appears, but then it just happens at a later rom. Judging from that 504 error message, it seems to have something to do with mirror.screenscraper.fr . As I said it all worked perfectly on the weekend a few days ago.
                          @rsn8887 sselph's scraper uses no mirror. It has something to do with the database and not with the scraper itself. There is nothing I can do. You can complain about it on IRC XD
                          Update: I just tried it and saw the mirror thing you mentioned. But no idea what that is! I'll talk with the people there and ask.
                          Update 2: some kind of dns problem. They already are aware of it and are working on it. So just be patient 😉
                          • screech
                            screech last edited by
                            Normally it's OK now 😉
                              paradadf Staff @screech last edited by
                              @screech thanks for the heads up!
                              • rsn8887
                                Yup it works just fine again 🙂
                                • rsn8887
                                  Well, I was a bit fast now there are problems with N64 scraping. It gives "unknown image format" errors. Worked fine 2 hours ago.
                                  "GDB" scraping works fine, so it is again some problem with "ss" (maybe ss ist just inherently unstable?)
                                    paradadf Staff last edited by
                                    I just think they are having dns problems lately. Personally, I'd rather wait until it is working again (usually just a matter of hours) instead of using other sources. No other database can compete with SS in that sense. And gdb is definitely not more stable 🙂
                                    • faxesystem
                                      faxesystem last edited by
                                      I have the following problem. When setting 3dboxart as prefered cover art it get's downloaded when scraping for a single system. When I choose all 3dboxart gets scraped for gba but not for any other system. For all other console systems the 2dboxart gets downloaded. Can anyone confirm this?
                                      Greetings,
                                      Faxe
                                        paradadf Staff @faxesystem last edited by
                                        @faxesystem have you changed consoleImg=-console_img= to "3b" (mameImg=-mame_img="3b" for neogeo)?
                                        Only ScreenScraper retrieves 3d boxes, so you better don't change the source. And important... use .png for 3d boxes, otherwise you'll get a black background.
                                        • DavidinCT
                                          DavidinCT last edited by
                                          I tried this and so far getting no where.... I have maybe 500 roms... The Emulationstation folder is in the user path (c:)but, the roms are located on another drive(g:), so it's kind of broken up trying to keep the ROMS off the 😄 drive. With this the system works perfectly fine (config files are set right). I dropped this batch file in the root of the rom folder.
                                          The only problem when I run this, I just get a message of
                                          Error: The system was unable to find the specified registry key or value, Cant get the PS's language. English will be used.
                                          And a blinking _
                                          it's been sitting there for over an hour like this, never asked me to do anything. Am I doing something wrong ? Or should I be doing something different for my setup ?
                                            paradadf Staff @DavidinCT last edited by paradadf
                                            @DavidinCT what do you mean by "the emulationstation folder"?
                                            What is your OS's language?
                                            What windows version do you have?
                                            DavidinCT 1 Reply Last reply Reply Quote 0
                                            101.0k
