    [BASH] Scrape your roms on macOS and Linux - fastscraper
    Community projects
    [bash] scrape roms linux fastscraper
    10163
      paradadf Staff last edited by paradadf
      Well, this is actually very experimental for me because I have actually no idea about bash scripting, but it appears to be working. I only tested it on Ubuntu and it worked perfectly, but I'm not a programmer so neither my code is nice nor I know if I'll be able to port every single function to it (specially to macOS).
      I just hope our friends on other OSs than Windows have now an easier way to scrape than before.
      From the command-line type the following to set appropriate permissions if needed:
      chmod u+x ./fastscraper
      Any feedback is very welcome!
      Download the latest version here!
      The original batch file thread can be found here.
      jackalpret 1 Reply Last reply Reply Quote 2
      • airart
        airart last edited by
        I try it tonight, the procedure is the same as on windows?
          paradadf Staff @airart last edited by
          @airart said in [BASH] Scrape your roms on macOS and Linux - fastscraper:
          more or less... you need to set the permission with the chmod as stated above.
          • jackalpret
            jackalpret Translator @paradadf last edited by
            @paradadf I tried on linux and macos and works perfect.
            I download fastscraper and give execution permission with :
            chmod +x fastscraper
            and then execute with:
            ./fastcraper
            and ready !
            • Víctor Téllez
              Víctor Téllez last edited by
              I will try it on mac os tonight
              • Jesús BL
                Jesús BL last edited by
                I run on the same raspberry pi 2 and runs ok!
                How can I send you information about 'No valid roms found in zip'?
                Trucos y recetas para raspberry pi:
                http://malagaoriginal.blogspot.com.es/search/label/raspberry pi
                  With sselph scraper, you can't. It doesn't generate a list like UXS does.
