    [BATCH] Scrape your roms on your PC - fastscraper
    Community projects
    multiconsole scraper fastscraper
    37
    221
    286011
    • maximus37
      maximus37 last edited by paradadf
      This tool is fantastic!! Nice work!!
      One problem though, I cannot scrape NeoGeo roms, I get the following output:
      2017/01/10 10:06:56 arcade  srcs: ss
      2017/01/10 10:06:56 console srcs:
      2017/01/10 10:06:56 INFO: Starting: C:\Users[...]\Downloads\neogeo\3countb.zip
      2017/01/10 10:06:56 INFO: Starting: C:\Users[...]\Downloads\neogeo\2020bba.zip
      2017/01/10 10:06:56 INFO: Starting: C:\Users[...]\Downloads\neogeo\2020bbh.zip
      2017/01/10 10:06:56 INFO: Starting: C:\Users[...]\Downloads\neogeo\2020bb.zip
      2017/01/10 10:06:58 ERR: error processing C:\Users[...]\Downloads\neogeo\2020bb.zip: image: unknown format
      2017/01/10 10:06:58 INFO: Starting: C:\Users[...]\Downloads\neogeo\2020bb.zip
      2017/01/10 10:06:58 ERR: error processing C:\Users\\Downloads\neogeo\2020bbh.zip: image: unknown format
      2017/01/10 10:06:58 INFO: Starting: C:\Users[...]\Downloads\neogeo\2020bbh.zip
      2017/01/10 10:06:58 ERR: error processing C:\Users[...]\Downloads\neogeo\3countb.zip: image: unknown format
      2017/01/10 10:06:58 INFO: Starting: C:\Users[...]\Downloads\neogeo\3countb.zip
      2017/01/10 10:06:58 ERR: error processing C:\Users[...]\Downloads\neogeo\2020bba.zip: image: unknown format
      2017/01/10 10:06:58 INFO: Starting: C:\Users[...]\Downloads\neogeo\2020bba.zip
      2017/01/10 10:06:58 ERR: error processing C:\Users[...]\Downloads\neogeo\2020bbh.zip: image: unknown format
      2017/01/10 10:06:58 INFO: Starting: C:\Users[...]\Downloads\neogeo\alpham2.zip
      panic: runtime error: invalid memory address or nil pointer dereference
      [signal 0xc0000005 code=0x0 addr=0x14 pc=0x408fe7]
      goroutine 22 [running]:
      panic(0x7e9580, 0x113a0030)
              /usr/local/go/src/runtime/panic.go:500 +0x331
      main.crawlROMs.func2(0x11472820, 0x114aa900, 0x0, 0x11472810, 0x114755a0, 0x11475520)
              /home/sselph/go/src/github.com/sselph/scraper/scraper.go:295 +0x527
      created by main.crawlROMs
              /home/sselph/go/src/github.com/sselph/scraper/scraper.go:328 +0xbd7
      Start    : 10:06:56.62
      Finish   : 10:06:58.67
      Duration : 00:00:02,05
        Hello @maximus37
        the server for arcade is down.
        maximus37 1 Reply Last reply Reply Quote 0
        • maximus37
          maximus37 @acris last edited by
          @acris Oh, well that explains it 🙂
          How can I check the status of it? How long has it been down? Is there a site I can keep an eye on?
          Thanks!
            paradadf Staff @maximus37 last edited by
            @maximus37 @acris The problem with NEOGEO right now (using SS as source) is explained here: https://github.com/sselph/scraper/issues/128
            So most likely sselph will need to compile a new version with the corrections to allow us to scrape it.
            • maximus37
              maximus37 @paradadf last edited by
              @paradadf Thanks for the link!
              • maximus37
                maximus37 @maximus37 last edited by
                @paradadf Hi, I noticed the issue was fixed? Do I simply download the latest version of fastscraper? Do I need to include any options for the scraping?
                  paradadf Staff @maximus37 last edited by paradadf
                  @maximus37 it wasn't a problem from sselph's scraper, but from the default used database (SS). So the version you have should work. But it is always better to use the latest 😉
                  About the options, on top of the batch you can modify the different flags to your taste, change sources, type of images, etc. So is up to you which configuration you prefer.
                  • airart
                    airart last edited by
                    I try to download or copy fastscraper.bat new version but server is down
                    • kevinnash
                      kevinnash last edited by
                      Github is OK on my side : https://raw.githubusercontent.com/paradadf/recaltools/master/fastscraper/fastscraper.bat
                      airart 1 Reply Last reply Reply Quote 0
                      • airart
                        airart @kevinnash last edited by
                        @kevinnash is new version ? is not working .... i'm so sad
                          paradadf Staff @airart last edited by
                          @airart it is working... you need scraper v.1.2.0 (latest version).
                          • airart
                            airart @paradadf last edited by
                            @paradadf said in [BATCH] Scrape your roms on your PC - fastscraper:
                            scraper v.1.2.0
                            Can U give me a link please , i've already copy raw fastscraper
                              @airart just delete the scraper.exe you have and launch the batch.
                              • airart
                                Err processing
                                ....xml syntax error on line 1
                                  @airart open the batch file, you probably have something else inside as the actual code.
                                  • airart
                                    maybe ..... i have copied raw in existing .bat overwryte all , can you give me a clean .bat ?
                                      @airart @kevinnash already gave you the direct link!
                                      right-click on it and and "save link as..."
                                      the clean link has always been online for everyone!
                                      • airart
                                        alt text
                                        not working xml syntax error on line 1
                                          paradadf Staff @airart last edited by paradadf
                                          @airart what is not working? where do you get that error? what version of sselph's scraper do you have?
                                          • airart
                                            @paradadf sselph v1.2.0
                                            i'm in pc platform not connected to recalbox because at home i have a mac system
                                            alt text
                                            101.0k
