    [BATCH] Scrape your roms on your PC - fastscraper
    Community projects
    multiconsole scraper fastscraper
    37
    221
    286011
      paradadf Staff @Erinjy last edited by
      @Erinjy read the instructions! this works only on WINDOWS!
      Erinjy 1 Reply Last reply Reply Quote 0
      • Erinjy
        Erinjy @paradadf last edited by Erinjy
        @paradadf said in [BATCH] Scrape your roms on your PC - fastscraper:
        Thx for the quick reply, that was the failure. I got another problem now though: When i copy the xml and the image folder onto the PI the images arent shown and if i update the gameliste via the ui it always resets the gamelist (your.bat created) and nothing happens...
        thx
        Edit: It seems that the gamelist created by your .bat doesnt contain the right path, how can i change that?
          @Erinjy it contains the right path... You must stop EmulationStation before copying the gamelist.xml with the command: /etc/init.d/S31emulationstation stop and start it again after the copy is finished with /etc/init.d/S31emulationstation start
          • Erinjy
            that worked, thx alot.
            • slakka
              slakka last edited by slakka
              Just tried this yesterday, worked very well but had a few problems.
              atari5200 and supergrafx had no successful scrapes. ROMs are from No-Intro set.
              FBA had almost no successful scrapes, only 154 out of 4156 worked, that number should have been several hundred right? Or should it be almost all of them?
              I thought maybe the directory name causes it to scrape from different sources so I tried fba, fba_libretro, and mame, same results for all. ROMs are from the set called FBA v0.2.97.38 .
              Maybe there is still a problem with mamedb causing so many failures?
                paradadf Staff @slakka last edited by paradadf
                @slakka sselph's scraper doesn't use ScreenScraper as a source for arcade systems and mamedb has been offline for weeks, so your success rate will be very low there.
                Wirh this batch, as long as your folders have the words fba, fba_libretro, mame or neogeo, it will be recognized as arcade, with the different options currently available. Even, for example, fbaANYTHING_ELSE will recognize the fba from the beginning.
                About atari 5200... I have never scraped that system and have no idea about how full the database is. The no-intro romset for supergrafx is definitely on the database (there are only 5 games). But if you have problems scraping your roms, then double-check the SHA1 of your files with the ones on SS. If they are not the same, and for the new roms to be added, you need either a software called FCRC-Calculator (check the MD5 hash) or the missing.txt from another scraper called Universal XML Scraper (scraper with much more options and recognizes arcadd systems ;)) to be submitted on IRC at #screenzone.
                Look for the how to about screenscraper and the tutorials about Universal XML Scraper (short: UXS) on this forum.
                slakka 1 Reply Last reply Reply Quote 0
                • slakka
                  slakka @paradadf last edited by
                  @paradadf Ok so I guess arcade scrape is out for now.
                  I checked a few of the Atari 5200 ROMs, SHA1 values matched those on SS. There's data there, descriptions, box art, etc. and the total number of ROMs from No-Intro's set is the same as the total number of games on SS, 107 games. Maybe my directory name should be different?
                  Thanks.
                    @slakka directory names are only important if you scrape arcade systems. For the rest, you can call your folders whatever you want. The only thing I can think of is that sselph's scraper hashes the unzipped rom, so even if the .zip hash is on the database, the .a56 (or whatever) might not. Those are the ones that need to be added.
                    • eb2016
                      eb2016 last edited by
                      what database/website does it get its data from? I'm keen to have a look.
                        paradadf Staff @eb2016 last edited by
                        @eb2016 all the information is here.
                        For example:
                        https://forum.recalbox.com/topic/2594/batch-scrape-your-roms-on-your-pc-fastscraper/9
                        • eb2016
                          eb2016 last edited by eb2016
                          Does this have issues at all with Gameboy Advanced? I just ran it on a bunch of systems and it worked fine but it didn't scrape any of my GBA titles.
                            paradadf Staff last edited by
                            Please, read the thread if you want to know how everything work. Just a few messages before I wrote this:
                            https://forum.recalbox.com/topic/2594/batch-scrape-your-roms-on-your-pc-fastscraper/48
                            It depends on the data source you choose and if the rom hash is in that database. Like all scrapers, it is always better to use no-intro romsets.
                            wggallagher 1 Reply Last reply Reply Quote 1
                            • wggallagher
                              wggallagher @paradadf last edited by
                              @paradadf Can you please explain to me what im doing wrong? Ive downloaded scraper.exe and fastscraper.
                              Ive put them in a folder called "roms" on my desktop and inside said folder are all the systems with roms that i want to scrap. I click on fast scraper, it starts, asks me "which systems do i want to scrape? All? " i enter "all"
                              then i append the existing game list. hit enter and nothing happens. What am i doing wrong?
                                paradadf Staff @wggallagher last edited by paradadf
                                @wggallagher it is impossible that nothing happened... what does the console says? Do you get the duration? Have you downloaded the correct scraper.exe (64bit version on a 32bit computer)?
                                • wggallagher
                                  @paradadf I believe so, I'm running Windows 10. I downloaded the windows386 .zip. should be the right one.
                                  paradadf wggallagher 2 Replies Last reply Reply Quote 0
                                    @wggallagher what does the console says after you press ENTER on the appending questions?
                                    wggallagher 1 Reply Last reply Reply Quote 0
                                    • wggallagher
                                      wggallagher @wggallagher last edited by
                                      @wggallagher 64 bit computer
                                      • wggallagher
                                        @wggallagher nothing. It just goes off screen. Like it closes
                                          @wggallagher what happens if you type a specific folder?
                                          • wggallagher
                                            @paradadf if I run fast scraper as admin, it says I dont have scraper.exe, even though I do, and asks if if like to go to the website to get it
                                            101.0k
