    Lightgun Wiimote + Nunchuk button remapping
    GamePad/GPIO/USB encoder
    lightgun wiimote nunchuk button remapping
    • Madmeggo
      Madmeggo last edited by Madmeggo
      Hi all!
      I recently upgraded to a Pi4 and invested in a Mayflash Dolphin Bar to finally play lightgun shooter! This has been a dream of mine for a long time. Shooting with the Wiimote works as it should, but is boring without a "gun case". So I bought a Speedlink Mr. Smith . It has a Nunchuk integrated, I thought that would be pretty handy. But it isn't...
      When I insert the Wiimote the Trigger stops working and I can't shoot with it anymore. Now I have to shoot by pressing the "A" Button on the Wiimote or by pressing the bottom of the pistol grip (I think this is the "Z" Button)
      I searched in the Recalbox documentation and found out that the "A" and "B" buttons on the Wiimote get reversed if a Nunchuk is connected which explains my problem. Why does this happen?
      I tried to remap the buttons in the Retroarch menu (Settings -> Input-> Port 1 Controls) but even after saving, it doesn't work.
      Is there any way to remap the buttons and make the Wiimote act "normal" again? It's a shame that I can't use this cool controller 😞
      • Madmeggo
        I did a little more testing and actually the remapping works on some systems.
        The systems it works on are Playstation 1, Dreamcast and Mastersystem.
        But on NES, SNES, and Mega Drive/Genesis the button remapping doesn't work.
        Why?
          Zing Global moderator Translator @Madmeggo last edited by
          @madmeggo See if this helps:
          https://wiki.recalbox.com/en/basic-usage/features/lightgun-on-recalbox
          • Madmeggo
            Sadly this doesn't help. I already looked in the documentation and this is the place where I read that the buttons are switched.
            It doesn't say how this can be fixed for some systems. As I said I can change the buttons in the Playstation, Mastersystem and Dreamcast retroarch Menu, but on NES, Megadrive and SNES this doens't work.
            101.4k
