    Muppen64plus glide64mk2 - no video on RbPi4 (recalbox 8)
    Emulator Arcade/PC/Console
    muppen64plus glide64mk2 rbpi4 recalbox
    3210
    • IGA
      IGA last edited by
      Hardware: Pi 4 - 4gb
      Power supply: 5V 3A Power Supply
      Recalbox 8
      Built From: Pre made from website pi4 image
      USB: logitech keyboard
      Controller: saitek x-box 360 controller
      VideoOut: crt-tv via composite !
      Next question about 8 version - No video in any games ( only audio) in default emulator Muppen64plus glide64mk2.
      Is only me has this issue? Maybe because i've use composite?
      Other emulators\cores work normal ( i mean shows picture) and they can always be used. But then why Muppen64plus glide64mk2 is chosen as default?
      Ledreum 1 Reply Last reply Reply Quote 0
      • Ledreum
        Ledreum @IGA last edited by
        @iga Hello i've got the same issue with rpi4 4 4 GB on the pi boy dmg.I change it for mupen64 plusrice with core game format ans it run.
        davidb2111 1 Reply Last reply Reply Quote 0
        • davidb2111
          davidb2111 Staff @Ledreum last edited by
          Hi @ledreum
          mupen64plus will be fixed in the next release (8.0.1)
          IGA 1 Reply Last reply Reply Quote 2
          • IGA
            IGA @davidb2111 last edited by
            @davidb2111 На-На))
            everything now is clear...
            IGA 1 Reply Last reply Reply Quote 0
            • IGA
              IGA @IGA last edited by
              Hello!
              Now (in 8.0.2) problem with video output is solved.
              But it's slow! More slower than 3 others emulators\cores that could choose...|
              So, how could configurate Muppen64plus glide64mk2 on rbpi4? ( maybe some menu from keyboard, when press esc - exit from emulator, or where some config file located...?)
              • davidb2111
                davidb2111 Staff @IGA last edited by
                Hi @iga
                Which rom did you try? Glide64mk2 may not be the good candidate regarding performances
                IGA 2 Replies Last reply Reply Quote 0
                • IGA
                  @davidb2111 Any!
                  well, let it be 007, the world is not enough, as the first in list....
                  I'm just want menu with some options which i could set up for emulator ( maybe increase fps, or make them visible) - all very slow then other emulators - why it as default?
                  • davidb2111
                    Because it would work well with other roms that other emulators may not run full speed.
                    • IGA
                      @davidb2111 said in Muppen64plus glide64mk2 - no video on RbPi4 (recalbox 😎:
                      I still don't understand....
                      in most test of my roms Muppen64plus glide64mk2 was most slower at recalbox
                      Instead at retropie Mupen64plus glide64 show most speed and performance ( best on retropie)
                      So, i ask allow some options to configurate it for best performance, cause at default starts it's run slow at recalbox....
                      • IGA
                        How could configurate this emulator?
                        davidb2111 2 Replies Last reply Reply Quote 0
                        • davidb2111
                          @iga said in Muppen64plus glide64mk2 - no video on RbPi4 (recalbox 😎:
                          Check the config files in SHARE:\system\configs\mupen64\
                          There is one configuration: mupen64plus.cfg which contain a section [Video-Glide64mk2]. You can take a look there.
                          • davidb2111
                            @iga
                            Also check the resolution of mupen from recalbox.conf, parameter n64.videomode. If not set, it will use global.videomode. You could try to set a lower resolution (1280x720 or so) in n64.videomode.
                            IGA 1 Reply Last reply Reply Quote 1
                            • IGA
                              @davidb2111 Thank you
                              • IGA
                                @davidb2111 But the games still looked like hard-hard frameskip ( music\sound plays well)
                                And i still couldn't enable fps. I open mupen64plus.cfg by notepad and write show_fps = 1. But, after Rbpi booting and launching Muppen64plus glide64mk2, there is still show_fps = 4 in mupen64plus.cfg
                                • How to fix it?
                                There my mupen64plus.cfg:
                                [64DD]
                                Disk = ""
                                IPL-ROM =
                                [Audio-OMX]
                                BUFFER_SIZE = 4096
                                DEFAULT_FREQUENCY = 32000
                                DEFAULT_MODE = 0
                                LATENCY = 300
                                NATIVE_MODE = False
                                OUTPUT_PORT = 1
                                SWAP_CHANNELS = False
                                UNDERRUN_MODE = 0
                                Version = 1
                                [Audio-SDL]
                                AUDIO_SYNC = False
                                DEFAULT_FREQUENCY = 33600
                                PRIMARY_BUFFER_SIZE = 16384
                                PRIMARY_BUFFER_TARGET = 10240
                                RESAMPLE = "trivial"
                                SECONDARY_BUFFER_SIZE = 2048
                                VOLUME_ADJUST = 5
                                VOLUME_CONTROL_TYPE = 1
                                VOLUME_DEFAULT = 80
                                Version = 1
                                [Core]
                                AutoStateSlotIncrement = False
                                CountPerOp = 0
                                CountPerOpDenomPot = 0
                                CurrentStateSlot = 8
                                DelaySI = True
                                DisableExtraMem = False
                                EnableDeb****r = False
                                GbCameraVideoCaptureBackend1 = ""
                                NoCompiledJump = False
                                OnScreenDisplay = True
                                R4300Emulator = 2
                                RandomizeInterrupt = True
                                SaveDiskFormat = 1
                                SaveSRAMPath = /recalbox/share/saves/n64
                                SaveStatePath = /recalbox/share/saves/n64
                                ScreenshotPath = /recalbox/share/screenshots
                                SharedDataPath = "/recalbox/share/system/configs/mupen64/"
                                SiDmaDuration = -1
                                Version = 1.010000
                                [CoreEvents]
                                Joy Mapping Decrease Volume = ""
                                Joy Mapping Fast Forward = "J0B10/H0V2"
                                Joy Mapping Frame Advance = ""
                                Joy Mapping Fullscreen = ""
                                Joy Mapping Gameshark = ""
                                Joy Mapping Increase Volume = ""
                                Joy Mapping Increment Slot = "J0B10/H0V1"
                                Joy Mapping Load State = "J0B10/B3"
                                Joy Mapping Mute = ""
                                Joy Mapping Pause = ""
                                Joy Mapping Reset = "J0B10/B1"
                                Joy Mapping Save State = "J0B10/B2"
                                Joy Mapping Screenshot = "J0B10/B4"
                                Joy Mapping Speed Down = ""
                                Joy Mapping Speed Up = ""
                                Joy Mapping Stop = "J0B10/B9"
                                Kbd Mapping Decrease Volume = 91
                                Kbd Mapping Fast Forward = 102
                                Kbd Mapping Frame Advance = 47
                                Kbd Mapping Fullscreen = 0
                                Kbd Mapping Gameshark = 103
                                Kbd Mapping Increase Volume = 93
                                Kbd Mapping Increment Slot = 0
                                Kbd Mapping Load State = 288
                                Kbd Mapping Mute = 109
                                Kbd Mapping Pause = 112
                                Kbd Mapping Reset = 290
                                Kbd Mapping Save State = 286
                                Kbd Mapping Screenshot = 293
                                Kbd Mapping Slot 0 = 48
                                Kbd Mapping Slot 1 = 49
                                Kbd Mapping Slot 2 = 50
                                Kbd Mapping Slot 3 = 51
                                Kbd Mapping Slot 4 = 52
                                Kbd Mapping Slot 5 = 53
                                Kbd Mapping Slot 6 = 54
                                Kbd Mapping Slot 7 = 55
                                Kbd Mapping Slot 8 = 56
                                Kbd Mapping Slot 9 = 57
                                Kbd Mapping Speed Down = 291
                                Kbd Mapping Speed Up = 292
                                Kbd Mapping Stop = 27
                                Version = 1
                                [Input-SDL-Control1]
                                A Button = "button(0)"
                                AnalogDeadzone = "4096,4096"
                                AnalogPeak = "32768,32768"
                                B Button = "button(2)"
                                C Button D = "axis(3+)"
                                C Button L = "axis(2-)"
                                C Button R = "axis(2+) button(1)"
                                C Button U = "axis(3-) button(3)"
                                DPad D = "hat(0 Down)"
                                DPad L = "hat(0 Left)"
                                DPad R = "hat(0 Right)"
                                DPad U = "hat(0 Up)"
                                L Trig = "button(4)"
                                Mempak switch = "button(11)"
                                MouseSensitivity = "2.00,2.00"
                                R Trig = "button(5)"
                                Rumblepak switch = "button(12)"
                                Start = "button(9)"
                                X Axis = "axis(0-,0+) axis(0+,0-)"
                                Y Axis = "axis(1-,1+) axis(1+,1-)"
                                Z Trig = "button(6)"
                                device = 0
                                mode = 2
                                mouse = False
                                name = "Saitek P3200 Rumble Pad - PC/Xbox 360"
                                plugged = True
                                plugin = "2"
                                version = 2
                                [Input-SDL-Control2]
                                A Button = ""
                                B Button = ""
                                C Button D = ""
                                C Button L = ""
                                C Button R = ""
                                C Button U = ""
                                DPad D = ""
                                DPad L = ""
                                DPad R = ""
                                DPad U = ""
                                L Trig = ""
                                Mempak switch = ""
                                R Trig = ""
                                Rumblepak switch = ""
                                Start = ""
                                X Axis = ""
                                Y Axis = ""
                                Z Trig = ""
                                device = -1
                                mode = 2
                                mouse = False
                                name = ""
                                plugged = False
                                plugin = 1
                                version = 2
                                [Input-SDL-Control3]
                                A Button = ""
                                B Button = ""
                                C Button D = ""
                                C Button L = ""
                                C Button R = ""
                                C Button U = ""
                                DPad D = ""
                                DPad L = ""
                                DPad R = ""
                                DPad U = ""
                                L Trig = ""
                                Mempak switch = ""
                                R Trig = ""
                                Start = ""
                                X Axis = ""
                                Y Axis = ""
                                Z Trig = ""
                                device = -1
                                mode = 2
                                mouse = False
                                name = ""
                                plugged = False
                                plugin = 1
                                version = 2
                                [Input-SDL-Control4]
                                A Button = ""
                                B Button = ""
                                C Button D = ""
                                C Button L = ""
                                C Button R = ""
                                C Button U = ""
                                DPad D = ""
                                DPad L = ""
                                DPad R = ""
                                DPad U = ""
                                L Trig = ""
                                Mempak switch = ""
                                R Trig = ""
                                Start = ""
                                X Axis = ""
                                Y Axis = ""
                                Z Trig = ""
                                device = -1
                                mode = 2
                                mouse = False
                                name = ""
                                plugged = False
                                plugin = 1
                                version = 2
                                [Rsp-HLE]
                                AudioListToAudioPlugin = False
                                DisplayListToGraphicsPlugin = True
                                RspFallback = ""
                                Version = 1.000000
                                [Transferpak]
                                GB-ram-1 = ""
                                GB-ram-2 = ""
                                GB-ram-3 = ""
                                GB-ram-4 = ""
                                GB-rom-1 = ""
                                GB-rom-2 = ""
                                GB-rom-3 = ""
                                GB-rom-4 = ""
                                [UI-Console]
                                AudioPlugin = "mupen64plus-audio-sdl.so"
                                InputPlugin = "mupen64plus-input-sdl.so"
                                PluginDir = "./"
                                RspPlugin = "mupen64plus-rsp-hle.so"
                                Version = 1
                                VideoPlugin = "/usr/lib/mupen64plus/mupen64plus-video-glide64mk2.so"
                                [Video-GLideN64]
                                EnableCopyColorToRDRAM = 0
                                EnableFBEmulation = False
                                EnableLegacyBlending = True
                                ShowFPS = True
                                UseNativeResolutionFactor = 1
                                bilinearMode = 1
                                [Video-General]
                                AspectRatio = True
                                Fullscreen = False
                                Rotate = 0
                                ScreenHeight = 480
                                ScreenWidth = 720
                                VerticalSync = False
                                [Video-Glide64mk2]
                                adjust_aspect = -1
                                alt_tex_size = -1
                                aspect = -1
                                buff_clear = -1
                                card_id = 0
                                clip_zmax = -1
                                clip_zmin = -1
                                clock = False
                                clock_24_hr = True
                                correct_viewport = -1
                                decrease_fillrect_edge = -1
                                detect_cpu_write = -1
                                fast_crc = -1
                                fb_crc_mode = -1
                                fb_get_info = -1
                                fb_hires = -1
                                fb_read_alpha = -1
                                fb_read_always = -1
                                fb_render = -1
                                fb_smart = -1
                                filtering = -1
                                fog = -1
                                force_calc_sphere = -1
                                force_microcheck = -1
                                force_polygon_offset = False
                                force_quad3d = -1
                                ghq_cache_save = True
                                ghq_cache_size = 128
                                ghq_cmpr = 0
                                ghq_enht = 0
                                ghq_enht_cmpr = False
                                ghq_enht_f16bpp = False
                                ghq_enht_gz = True
                                ghq_enht_nobg = False
                                ghq_enht_tile = 0
                                ghq_fltr = 0
                                ghq_hirs = 0
                                ghq_hirs_altcrc = True
                                ghq_hirs_cmpr = False
                                ghq_hirs_dump = False
                                ghq_hirs_f16bpp = False
                                ghq_hirs_gz = True
                                ghq_hirs_let_texartists_fly = False
                                ghq_hirs_tile = False
                                hires_buf_clear = -1
                                ignore_aux_copy = -1
                                increase_texrect_edge = -1
                                lodmode = -1
                                n64_z_scale = -1
                                old_style_adither = -1
                                optimize_texrect = -1
                                pal230 = -1
                                polygon_offset_factor = 0
                                polygon_offset_units = 0
                                read_back_to_screen = -1
                                show_fps = 4
                                ssformat = False
                                stipple_mode = -1
                                stipple_pattern = -1
                                swapmode = -1
                                texture_correction = -1
                                use_sts1_only = -1
                                useless_is_useless = -1
                                vsync = True
                                wrpAnisotropic = True
                                wrpAntiAliasing = 0
                                wrpFBO = True
                                wrpResolution = 0
                                wrpVRAM = 0
                                zmode_compare_less = -1
                                [Video-Rice]
                                AccurateTextureMapping = True
                                AnisotropicFiltering = 0
                                CacheSize = 100
                                ColorQuality = 1
                                CropMode = 1
                                DefaultCombinerDisable = False
                                DoubleSizeForSmallTxtrBuf = False
                                DumpTexturesToFiles = False
                                EnableHacks = True
                                EnableSSE = True
                                EnableVertexShader = False
                                FastTextureLoading = False
                                FogMethod = 1
                                ForcePolygonOffset = False
                                ForceTextureFilter = 2
                                FrameBufferSetting = 0
                                FrameBufferWriteBackControl = 1
                                FullTMEMEmulation = False
                                InN64Resolution = False
                                LoadHiResCRCOnly = True
                                LoadHiResTextures = False
                                Mipmapping = 2
                                MultiSampling = 0
                                NormalAlphaBlender = False
                                OpenGLDepthBufferSetting = 16
                                OpenGLRenderSetting = 0
                                OpenGLVertexClipper = False
                                PolygonOffsetFactor = 0
                                PolygonOffsetUnits = 0
                                RenderToTexture = 0
                                SaveVRAM = False
                                ScreenUpdateSetting = 7
                                ShowFPS = True
                                SkipFrame = False
                                SkipScreenUpdate = False
                                SmallTextureOnly = False
                                TexRectOnly = False
                                TextureEnhancement = 6
                                TextureEnhancementControl = 0
                                TextureQuality = 0
                                Version = 1
                                WideScreenHack = False
                                WinFrameMode = False
                                And yes, i've use crt. So, i opened n64.videomode and write ;n64.videomode=default
                                • but nothing changed
