    Black borders (up and down) recalbox 8 + pi2scart + crt
    borders down recalbox pi2scart crt
    6
    30
    7280
    • 0zzy
      0zzy @Wizzard last edited by
      @wizzard said in Black borders (up and down) recalbox 8 + pi2scart + crt:
      oblem in a few days after I get my pi2scart
      all pal games i have tried (more than a dozen, so i have to suppose all) for snes and genesis (i don't use any other console)
      • 0zzy
        0zzy @digitaLumberjack last edited by
        @digitalumberjack said in Black borders (up and down) recalbox 8 + pi2scart + crt:
        @0zzy yop o/
        Pal games are starting in PAL mode 50HZ like on the original pal hardware :
        there was black bars on pal games, as the mode was 288p with 224 or 240 pixel height games.
        We are working on a option to select the mode of pal games when starting it : PAL or NTSC.
        Just not implemented yet.
        Hi @digitalLumberjack , has been solved in Recalbox 8.0.1 ?
        digitaLumberjack 1 Reply Last reply Reply Quote 0
        • digitaLumberjack
          digitaLumberjack Staff @0zzy last edited by digitaLumberjack
          @0zzy yes the feature is present in recalbox 8.0.1, still experimental though. Enable the region selection from the crt menu.
          0zzy 1 Reply Last reply Reply Quote 0
          • 0zzy
            Hi @digitalLumberjack , i have enabled "select game refresh rate at launch" but snes games still have black bars,
            is there anything I can do to fix it?
            • digitaLumberjack
              @0zzy do you start them in 60hz ?
              0zzy 2 Replies Last reply Reply Quote 0
              • 0zzy
                @digitalumberjack i have enabled only these options, 2022-01-30 18_04_22-Window.png
                when i run a snes games, i have no other menu or voice to select between 50/60 hz
                what else i miss? is there another menu?
                • 0zzy
                  Hi @digitaLumberjack can you explain me how? I havent seen any particular setup about it.
                  • digitaLumberjack
                    @0zzy yes we have a little bug that will be fixed for the next release.
                    The 50/60hz mode cannot be forced yet
                    • 0zzy
                      Hi @digitalLumberjack is there a public release planning? I'm looking every day for a new release 📅 🙂
                      • 0zzy
                        0zzy last edited by
                        Hi, i'm waiting my own rgbdual but for now i have enabled this update using my pi2scart.
                        update.type=recalboxrgbdual
                        50/60 Hz selection is now available, and pal games on snes are more "wider" now, but the image is a few centimeters shifted down.
                        On EmulationStation the image is centered, is there an option to center the image only for specific emulators?
                        100.2k
