    Recalbox 7.2.2 PSP Cheats won't get loaded
    recalbox 7.2.2 psp cheats wont loaded
    • Lempo
      Lempo last edited by
      Re: ppsspp cheat
      Hi, i tried what was said in this topic i linked on top, but ppsspp won't import the cheats?
      i put the file in \recalbox\share\system\configs\ppsspp\PSP\Cheats\cheat.db but i can't import the cheats.
      Under retropie this works without problems... Where am I missing something?
        Zing Global moderator Translator @Lempo last edited by
        @lempo I believe the correct path is:
        \\RECALBOX\share\saves\psp\ppsspp\PSP\Cheats\cheat.db
        I think the path has changed between the latest versions of Recalbox, I saw a similar issue with LEONA's DLC in Metal Slug xx:
        • https://forum.recalbox.com/topic/24720/dlcs-psp
        But from what I've seen, for some reason they don't work in all games:
        • https://forum.recalbox.com/topic/24568/petits-retour-sur-rpi4-en-v7-2-2-pour-psp-et-n64/14
        I tested the 99 lives cheat on Metal Slug xx and it worked, but I couldn't get it to work on Jetpack Joyride for example (I don't even know if there are cheats for this game).
