    ppsspp cheat
    Your recalbox
    cheat ppsspp
    16092
    • njx45
      njx45 last edited by njx45
      i want use cheat on ppsspp of recalbox, but no option on the menu when i press HOTKEY+X。
      who can tell me how to use it ?
      my platform is recalbox 7.1.1 on respberrypi 3B.
      very thank you .
      • kripkeu
        kripkeu last edited by
        Hello, you need to find the cheats in .db and you copy them into the 'cheat' file of Recalbox, then in the settings of the ppsspp ,system ,then enable cheat.
        https://www.youtube.com/watch?v=lNdD6sbrM0E
        • kripkeu
          Example of the 'cheat' file.
          • kripkeu
            There is 4126 file ~5MB the file.
            • Shuu
              Shuu last edited by
              Hello,
              Another solution is to place a single cheat.db file in the folder:
              R:\recalbox\system\configs\ppsspp\PSP\Cheats
              (R: this is the letter of the usb key that I connect to my Rpi when connected to my computer)
              The file can be found on the following github:
              https://github.com/Saramagrean/CWCheat-Database-Plus-
              (it's the same file described in the video above)
              Then the approach in PPSSPP remains the same as described in the video
              Enjoy
              • joshi
                joshi Banned last edited by
                This post is deleted!
