    PSX memory card from .mcd (fpse) to recalbox .srm format converter?
    Emulator Arcade/PC/Console
    memory card mcd fpse recalbox srm format converter
    • lxknvlk
      lxknvlk last edited by
      Hello.
      I have memory cards from fpse in .mcd format. And in recalbox for odroid go super i see psx/saves files in format .srm.
      How can I convert my .mcd to .srm files?
        Zing Global moderator Translator @lxknvlk last edited by
        @lxknvlk I'm not sure, but searching quickly on the internet I saw some users reporting that a conversion is not necessary, renaming is enough, I recommend you try it out:
        • Get your file YOUR_SAVE_NAME.mcd
        • Identify the EXACT name of your rom (NAME_OF_YOUR_ROM.XXX)
        • Rename the file YOUR_SAVE_NAME.mcd to NAME_OF_YOUR_ROM.srm
        • Move your newly renamed file to the recalbox "saves" folder
        If that doesn't work, test using MemcardRex and converting your .mcd file to .mcr and then renaming it as I explained above.
        The tutorials I found relating to this are in French, but you can use google translator if you want to check it out:
        • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/jeux/consoles/playstation-1/convertir-sauvegarde-gme-en-srm
        • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/jeux/consoles/playstation-1/utiliser-vos-sauvegarde-mcr-epsxe-dans-retroarch-psx-srm
        And if you want, apparently you can use your .mcd file as memory card 2:
        • https://recalbox.gitbook.io/documentation/v/francais/tutoriels/jeux/consoles/playstation-1/activation-de-la-carte-memoire-2
        Please test and give feedback.
        • lxknvlk
          @zing said in PSX memory card from .mcd (fpse) to recalbox .srm format converter?:
          Yess! It works! Thank you very much!
          Simplified process:
          1. Take .mcd file (its the whole memory card file from fpse)
          2. Use MemcardRex and open it. Save As with .mcr format.
          3. Now name it to the exact rom name with .srm format
            And it should work.
