    [Pi4 7.2.2] Parallel_N64 core doesn´t save options on Retroarch
    [pi4 7.2.2] paralleln64 core doesn´t retroarch
    2734
    • Ark
      Ark last edited by
      Hi.
      I´m using Raspberry Pi4B (4gb ram), and when I want to try different configuration options for Parallel_N64, can´t save changes.
      Other emulators let me save without problems, but Parallel_N64 don´t save the changes.
      I also tried manually creating configuration file, but when starting Recalbox, it overwrites the options again.
      I have tried changing the settings also in the file "retroarch-core-options.cfg", but it is not possible either.
      It is impossible to change "parallel-n64-gfxplugin" from "automatic" to other option.
      Nintendo 64 does not work well on Pi 4 if the settings cannot be customized 😕 (default core Mupen64Plus_Next works worse).
      I´m using last versión 7.2.2.
        Zing Global moderator Translator @Ark last edited by
        @ark I recommend that you do a reset to factory defaults (Available through advanced settings), you will not lose any personal files, but you will lose all custom settings.
        See if this helps:
        https://forum.recalbox.com/topic/24280/n64-graphics-ok-on-first-start-only
        • Ark
          Ark last edited by
          @zing I've also tried doing that, but after restoring to factory settings it's still the same (I've even tried doing a clean install).
          I don't think this only happens to me, I think this error is general to everyone on Raspberry Pi 4.
          When I had Raspberry Pi 3B with "Mupen64Plus" Nintendo 64 worked better, but on Raspberry Pi 4 Nintendo 64 has become a nightmare:
          1. Libretro Mupen64Plus_Next (default core) works bad, with slowdowns.
          2. Libretro Parallel_N64 has good speed, but you can't fix the graphical errors because you can't customize the options (impossible to save the changes as I said).
          3. Mupen64Plus Glide64MK2 does not work in any game.
          4. Mupen64PlusRice does not work in any game.
          I hope this can be fixed because I think this error is general for all Raspberry Pi 4 users.
          Thanks for your time.
          Zing jorgemagana 2 Replies Last reply Reply Quote 0
            Zing Global moderator Translator @Ark last edited by Zing
            @ark
            Sorry, but I don't see reports from other users, so it can't be said that this happens to everyone.
            I saw that you have already opened an issue even before posting on the forum, so I recommend that you wait for a response from the issue:
            https://gitlab.com/recalbox/recalbox/-/issues/1780
            You can also try to check the official Discord if anyone else has the same issue, and if anyone else does, support your issue:
            https://discord.com/invite/NbQFbGM
            Ark 1 Reply Last reply Reply Quote 0
            • Ark
              Ark @Zing last edited by
              @zing Okay thanks!
              But it would be very rare if it only happened to me, even with clean installation.
              I hope I can fix it, it bothers me a lot not being able to play Nintendo 64.
              Thanks!
              • jorgemagana
                jorgemagana @Ark last edited by
                @ark I can confirm number 2. Libretro core Parallel_N64 doesnt' save options. I have a pi4 and Recalbox 8.
                • jorgemagana
                  jorgemagana last edited by
                  I don´t know if 8.02 fixed this problem, I did not uptade to that version. I'm waiting for 8.1
                  • jorgemagana
                    jorgemagana last edited by jorgemagana
                    Updated today to 8.02, still same problems Parallel_N64 core desn't save options in Retroarch.
                      Zing Global moderator Translator @jorgemagana last edited by
                      @jorgemagana And the Configuration override, does it work?
                      • https://wiki.recalbox.com/en/advanced-usage/configuration-override
                      • https://wiki.recalbox.com/en/advanced-usage/configuration-override/retroarch-overrides
                      jorgemagana 1 Reply Last reply Reply Quote 0
                      • jorgemagana
                        jorgemagana @Zing last edited by
                        @zing I have not experience with those files, but I will try.
