    IPAC2 Retroarch keys config doesn't save
    GamePad/GPIO/USB encoder
    ipac2 retroarch keys config doesnt
    • alvinicoogh
      alvinicoogh last edited by
      Hi all, I have a big issue with recalbox 7.2.2 and keys configuration with ipac2.
      The ipac2 is configurated as keyboard and MAME mapped.
      Recalbox is installed on a Intel NUC PC, with 2 HDs.
      When the system is running, keyboard is configured as ES config file, and I changed it with no problem.
      The issue is when i try to play with retroarch: keyboard doesn't have an hotkey to enter RA settings, so i plug in a Logitech USB Joypad, then i start a game (mame), i enter inside settings, controller, P1 and P2, I remap all the keyboard keys.
      I save the current configuration (in recalbox 7.2.2 the cfg file is called retroarchcustom.cfg) and resume the game. everything is fine.
      but if i quit the game (and so retroarch), the mapping becomes the default. By SFTP i can see that the file is overwritten by the system.
      I try everything i found on forums to have a permanent configuration, but nothing works for me.
      I don't want to configure ipac2 as a game controller, because the hardware is inside an old arcade cabinet, with coins and 7 buttons per player and i need the flexibility of a keyboard to make everything working right.
      Can you help me please?
      Thanks a lot.
      Zing 1 Reply Last reply Reply Quote -1
        Zing Global moderator Translator @alvinicoogh last edited by
        @alvinicoogh
        retroarchcustom.cfg
        It's not a problem, it's not that file you should edit.
        See if this helps:
        • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuring-custom-buttons/how-to-customize-controller-mapping
        • https://recalbox.gitbook.io/documentation/tutorials/controllers/configuring-custom-buttons/create-a-custom-configuration-by-emulator
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload
        • https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads
        alvinicoogh 1 Reply Last reply Reply Quote 0
        • alvinicoogh
          alvinicoogh @Zing last edited by
          @zing thank you very much for your answer.
          I tried to overload retroarch inputs by adding a .retroarch.cfg file in the roms directory.
          The content is:
          input_player1_a = "alt"
          input_player1_b = "ctrl"
          input_player1_y = "shift"
          input_player1_x = "z"
          input_player1_start = "1"
          input_player1_select = "5"
          input_player1_l = "space"
          input_player1_r = "x"
          input_player1_left = "left"
          input_player1_right = "right"
          input_player1_up = "up"
          input_player1_down = "down"
          I rebooted the system, but nothin is changed. Am I doing something wrong?
          I will try the first two options you suggested.
          Zing 2 Replies Last reply Reply Quote 0
            @alvinicoogh
            Sorry, but I'm not sure, as I quickly see in this tutorial:
            https://recalbox.gitbook.io/documentation/advanced-user/configuration/configuration-overload/retroarch-overloads#remapping-hotkeys
            To define the A key you need to fill in the field input_player1_a_btn and you used the term input_player1_a (missing the _btn at the end). Also, I believe there are no spaces and in your example there are spaces, check these details.
              Zing Global moderator Translator @alvinicoogh last edited by Zing
              @alvinicoogh Please don't SPAM:
              https://forum.recalbox.com/topic/24761/help-with-retroarch-configuration-overload
              There is no need for you to pollute the forum with multiple posts on the same subject, I will block this topic, but please don't do that again.
              • Locked by  Zing Zing
