    Kodi audio passthrough missing Pi4
    MediaCenter & Dualboot
    kodi audio passthrough missing pi4
    1618
    • qeb
      qeb last edited by
      Hi, does anybody know what happens with the audio passthrough in kodi. There's no option at all after the change to pulseaudio.
        Zing Global moderator Translator @qeb last edited by
        @qeb In the other topic you participated in, several possibilities were mentioned, it doesn't seem that you tested them:
        https://forum.recalbox.com/topic/23885/update-to-7-2-no-sound
        • qeb
          qeb last edited by
          Yes In 7.2 I reset factory settings as I was told and everything was ok again but with 7.2.1 the problem is that there's no passthrough options in kodi. Its a weird thing.
            @qeb See if it's not something related to this:
            https://forum.recalbox.com/topic/24423/sound-very-loud-when-returning-to-recalbox-from-kodi
            qeb 1 Reply Last reply Reply Quote 0
            • qeb
              qeb @Zing last edited by
              @zing I already read that post 100 times 😂😂😂 and try every solution posted. No luck at all.
              I think it's something related whith the pulseaudio or alsa driver but I can't figure what is it.
                @qeb Searching better, apparently there are other users with the same problem:
                • https://forum.recalbox.com/topic/24232/7-2-1-mode-passthrough-disparu-kodi
                • https://forum.recalbox.com/topic/24255/problèmes-pi4-kodi-en-7-2-1
                Apparently, a kodi update might fix the problem:
                https://www.raspberrypi.org/forums/viewtopic.php?t=250811
                As I mentioned in the other topic I mentioned earlier:
                " Kodi will be updated in version 7.3 of Recalbox, but it will take a while for this version to be released:
                https://gitlab.com/recalbox/recalbox/-/issues/1735 "
                So unfortunately I don't know if there is any solution to this problem.
