    sound very loud when returning to recalbox from kodi
    sound very loud returning recalbox kodi
    • neo207
      neo207 last edited by
      RETURNING FROM KODI TO RECALBOX MAKES THE MUSIC VERY LOUD.
      You solve this by lowering the volume, in my case from 50% to 49% and back to 50% again.
      I hope there is a fix soon because i switch between kodi and recalbox quite often.
        Zing Global moderator Translator @neo207 last edited by
        @neo207 From what I see here, you must have some configuration conflict because you are using some configuration from an old version, it has already been suggested for you to do a factory reset and it doesn't look like you did it.
        Sorry, but your problem still seems to be related to this.
        Can you test it on another SD card, with a clean installation of the latest version of Recalbox?
        When you say in your last post that you updated to 7.2.1, how did you do that?
        Open the Emulationstation main menu (by pressing Start), go to the advanced settings, and do the factory reset, you will not lose any personal files, but you will lose all customized settings. It is the easiest way to do it.
        Another option is to do what is in this video (enable subtitles):
        https://www.youtube.com/watch?v=skeULeTu7p8&list=PL2oNQ0AT7fx2ExiSNrfHUzga5GnogI4sh&index=23
        If you do not test with a 100% clean version of Recalbox, I cannot guarantee that you are not doing any wrong settings (since there are no other users reporting the same problem).
        When we have a singular problem, and we do not know the source, the recommended technique is to start from scratch, changing one configuration at a time and testing each change, it is the most guaranteed way to identify where the problem arises, and , automatically, which configuration generated the problem.
        I know that this may not be easy at times, but, as I said, it is the most guaranteed method (and this does not only apply to Recalbox), and, unfortunately, without witnessing the problem it is more difficult to help you.
        neo207 1 Reply Last reply Reply Quote 0
        • neo207
          neo207 @Zing last edited by
          @zing wait wait wait, i DID a factory reset after I wasn't able to fix all issues. I updated via the recalbox-menu.
            @neo207 I don't know what it could be, and I can't test it right now, can you test it on another SD card, with a totally clean install of the latest version?
            Kodi will be updated in version 7.3 of Recalbox, but it will take a while for this version to be released:
            https://gitlab.com/recalbox/recalbox/-/issues/1735
