    XBOX Series S/X Controller not pairing with Recalbox 7.1
    GamePad/GPIO/USB encoder
    7.1 pairing retrobox series xbox
    8
    14
    7097
    • zife
      zife last edited by zife
      Hi guys.
      I bought an xbox series s controller (robot white) but this controller won't pair with my raspberry PI 3 (recalbox version 7.1).
      I just changed the ERTM following this instructions (https://forum.recalbox.com/topic/17312/bluetooth-testers-wanted), but does not worked.
      Somenone could help me ?
      • KoSaK
        KoSaK last edited by
        hello, I have same problem...
        Tutorial from Your link for me was hard and I've done this for other way.
        I edit /etc/modprobe.d/bluetooth.conf file with help of Filezilla FTP.
        I try also PuTTy by logging and use this tutorial https://recalbox.gitbook.io/documentation/tutorials/controllers/configuration-test/manually-connect-a-bluetooth-control.
        Unfortunately no results.
        • KoSaK
          @zife
          try this"
          change the value of the line in recalbox.conf:
          controllers.bluetooth.ertm=1
          to
          controllers.bluetooth.ertm=0
          not tested.
          Khelann49 1 Reply Last reply Reply Quote 0
          • Khelann49
            Khelann49 @KoSaK last edited by Khelann49
            @KoSaK
            Hi guys,
            I have the same issue with a Raspberry 4 / Recalbox 7.1.1.
            Can't pair my Xbox Series Controller.
            I'll try changing the values quoted. Others getting the same issue?
            Thx!
            • KoSaK
              no support, sorry 😞
              https://recalbox.gitbook.io/documentation/hardware-compatibility/compatible-devices/controller
              • palabalo
                palabalo last edited by
                NO support!!! noooo! Do we have any idea why they are not supporting the wireless xbox one s? I mean if windows can do it? I was able to get it to pair, and connect on restart with 7.1.1 reloaded, but it wont work during emulation, Seems like its really close to working.
                what I did to get it to Pair (but wont work in emulation)
                nano /recalbox/share/system/recalbox.conf
                controllers.ps3.enabled=0
                This allows me to pair and configure just once i start a game it doesnt work.
                I also tried adding the lines below but they didnt change anything.
                Enable xboxdrv driver, disable this if you enabled ps3 controllers (0,1)
                controllers.xboxdrv.enabled=1
                Set the amount of controllers to use with xboxdrv (0..4)
                Seems so close to working anyone help?
                • Pitch64
                  Pitch64 Staff last edited by
                  Those controllers are not supported yet via bluetooth. You can use them only wired at this moment.
                  Next release? Soonâ„¢
                  xtc0r 1 Reply Last reply Reply Quote 0
                  • LeoShorter
                    LeoShorter last edited by
                    This post is deleted!
                    • xtc0r
                      xtc0r @Pitch64 last edited by
                      @pitch64 Is the XBOX one (S/X) controller meanwhile supported?
                      I see my controller during BT devices discovery but pairing fails.
                      If not supported yet, is it possible to install xpdadneo as this worked for me in retropie.
                      • Pitch64
                        We tried to include xpadneo but we got some fails, so it's not included at this time 🙂
                        • xtc0r
                          Thanks for the reply.
                          Is the implementation of xpadneo close or more far in the future?
                          If far away I will buy some other BT gamepad which already works. But if the implementation is soonish I would stick with my xbox controller.
                          Pitch64 1 Reply Last reply Reply Quote 0
                          • Pitch64
                            Pitch64 Staff @xtc0r last edited by
                            @xtc0r I'm not the one who tried to include it, I can't tell you.
                            https://gitlab.com/recalbox/recalbox/-/issues/1609
                            • pol9520
                              pol9520 last edited by pol9520
                              Hello, on my RPi4 and Recalbox 8.1.1, the controller Xbox series X 1914 not working in BT, the recalbox said the controller is succeeded paired but the light didn't stop blinking rapidly (pairing mode).
                              The controller work correctly in Raspberry Pi OS.
                              Any news ?
                              pol9520 1 Reply Last reply Reply Quote 0
                              • pol9520
                                pol9520 @pol9520 last edited by
                                @pol9520 it work on 9.0
                                Thanks
