    Daphne not working on 7.1.1 (RPI4)??
    daphne 7.1.1 rpi4
    1547
    • clkgames
      clkgames last edited by
      Hi there It's me again and this time I am having issues with Daphne.
      I cannot get any game to run..
      Example:
      Space Ace
      • ace.zip inside ROM folder;
      • folder: ace.daphne, size: 2.32GB ;
      • command file: ace.commands;
      Content of ace.commands:
      -bank 0 00000000 -bank 1 00000001
      Game won't run.
      I had the same rom set running flawlesly on Dragon Blaze 6.1.
      is there a known issue with 7.1.1 or is it just happening to me?
      Thanks
      • lmerckx
        lmerckx last edited by
        Hello @clkgames.
        No, Daphne runs without problems on Recalbox 7.1.1 on RPI4.
        I use the same ROMs and images than in previous versions.
        But, note that, I had some problems with my SSD disk.
        Don't know if it's general to my disk or PI, but I had some slowness on some games.
        For Daphne, some games (not all) simply freezed after some seconds (only video, not sound). When I came back to an HDD disk, the problem disappeared.
        What is your problem exactly ? The game doesn't start and it returns to the Emulation Station, or something else ?
        Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
        Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
        clkgames 1 Reply Last reply Reply Quote 1
        • lmerckx
          Also note, that the blinking problem which appears on some platforms (XU4 and PC - depending on the video card) should be solved (by vanfanel).
          I will propose a patch soon for next version of Recalbox.
          • clkgames
            clkgames @lmerckx last edited by
            @lmerckx thank you, I tried deleting all games and copying them back. No deal.
            The problem is, no matter what games I choose to run, I get a black screen and get back to game selection screen. I have tried several other games and I don’t understand what is going on...
            clkgames 1 Reply Last reply Reply Quote 0
            • clkgames
              clkgames @clkgames last edited by
              Well it seems I had a bad micro SD card. All is good now, thanks and apologies for that.
              • LapinFou
                LapinFou last edited by
                Tips n°1: never use the SD card to store your ROMs.
                Tips n°2: always use USB Flash Drive, HDD or even a SSD to store your ROMs.
                This will avoid the kind of issue you got, the SD card lifetime will be much longer and, finally, it will ease the full re-installation procedure. 😁
                • lmerckx
                  Great !
                  It seems that Daphne is very sensible to device read errors. Perhaps more than all other emulators.
                  Don't know really why but it is useful to know.
