    Overclocking "How to"??
    overclocking
    4704
    • southpaw32
      southpaw32 last edited by
      I have a few different Raspberry Pis, so I figured I'd turn one into a Recalbox.
      I'm running it on a Pi 400.
      I usually overclock my RPis, by editing the /boot/config.txt file, but that doesn't seem to be working on Recalbox. For one, it says it can't write to the file. Once I got past that, I'm not seeing an change in CPU speed with "watch -n 2 vcgencmd measure_clock arm"
      Do I edit "recalbox-config.txt" instead?
      What am I missing here? I've search, but haven't been able to find a good "How to" for OCing Recalbox.
        Zing Global moderator Translator @southpaw32 last edited by
        @southpaw32 For now, the place with the best information on overclocking is this post:
        https://forum.recalbox.com/topic/21649/overclocking-pi4-with-recalbox-7
        • southpaw32
          Thanks! I've got it figured out, so I'll post what I know.
          Basically, it's the same as overclocking in RPi OS.
          Edit the config file with: nano /boot/config.txt
          I used SSH to login to my box, but you could edit that file with a text editor on another system as well.
          On my Raspberry Pi 400 I used the following:
          over_voltage=6
          arm_freq=2200
          gpu_freq=750
          arm_freq_min=900
          Raising the Minimum to 900 seems to make things a little smoother. I might try raising that some more later.
          I was also having some audio stuttering in a couple of games so I adjusted:
          audio_pwm_mode=2
          Originally it was =514
          I've also heard you can try a =0
          You can verify your speed with: watch -n 2 vcgencmd measure_clock arm
          That shows you the speed the CPU is running at ever 2 seconds.
          Overall, it's just like overclocking in Raspberry Pi OS
          • LapinFou
            LapinFou last edited by
            @southpaw32 said in Overclocking "How to"??:
            over_voltage=6
            arm_freq=2200
            gpu_freq=750
            arm_freq_min=900
            You should first try with arm_freq = 2000. I read than a greater value could in fact underclock the CPU instead overclocking it. 😲
            With this setting (2GHz), I got about 10/15% more FPS with the Dreamcast emulator.
            • barbudreadmon
              barbudreadmon @LapinFou last edited by barbudreadmon
              @LapinFou said in Overclocking "How to"??:
              That's probably because when pi reach thermal threshold, it'll downclock to reduce the temp, it can happen on any pi with any freq, so always make sure your pi is properly cooled
              Libretro developper :
              • FBAlpha FBNeo (Arcade)
              • Kronos (Sega Saturn/ST-V)
              • YabaSanshiro (Sega Saturn)
              LapinFou 1 Reply Last reply Reply Quote 0
              • LapinFou
                LapinFou @barbudreadmon last edited by LapinFou
                @barbudreadmon said in Overclocking "How to"??:
                Not on my PI4. I'm using this Ice Tower. The CPU is dead cold. 😁
                From what I read, it is more an OS issue. Overclocking higher than 2GHz doesn't seem to work well.
