    No sound through hdmi (from pc to tv)
    sound through hdmi
    • machuichan
      machuichan last edited by
      Hello, first off all I would like to thank you all for your help and for this amazing project.
      I installed 2 days ago recalbox to a usb drive which i am running from a computer. I used a official image from the website x86 version for pc. Installed the image on the usb pen 64 gb and booted to it. Everything went perfectly. Loaded games all fine.
      Problem is I get no sound to my tv. I searched in many many posts in this forum for help. I did find some random comment saying i could go into the retroarch menu inside of a game and try to mess arround with audio settings in there which i did successfully and I now have sound in game. Great!
      Good to point out I also get sound in kodi no problem.
      Problem is, In the main screen of recalbox I dont get sound at all. I did find some random comment talking about a problem with nvidia graphics card "incompatibility"??. I do have a nvidia graphics card in this pc. My hdmi options are only hdmi 0 (Trying a different pc with different graphics card on the SAME tv, the sound worked perfectly)
      So my question is: is recalbox actually not compatible with my nvidia graphics card and there is no fix to it and I should just let it go or is there something I can do?
      Thank you very much and sorry for writing so much, I just wanted to be sure you could understand my problem.
      Hoping for an answer!
      Gui
      machuichan 1 Reply Last reply Reply Quote 0
      • machuichan
        machuichan @machuichan last edited by
        @machuichan
        Just in case is helpful
        The pc is an old one. With an Intel Pentium dual core cpu, 4GB memory ram. The other pc I tried is exactly the same, same everything, except different graphics card.
        Thank you
        • machuichan
          @machuichan b*mp
            Zing Global moderator Translator @machuichan last edited by
            @machuichan If the problem were an incompatibility with the video card, there would not be much to do, BUT, from what you are describing, I do not believe that it is.
            See if any of these topics help you:
            • https://forum.recalbox.com/topic/22796/after-4-reboots-not-audio-working
            • https://forum.recalbox.com/topic/21453/recalbox-7-plus-de-son-en-hdmi-pc64
            • https://forum.recalbox.com/topic/22614/no-sound-over-hdmi
