    Recalbox 7.1.1 can't run on Pi4.
    recalbox 7.1.1 cant run pi4
    1171
    • dokaponking
      dokaponking last edited by
      Recalbox 7.1.1 can't run on Pi4. Black screen.
      robmcc83 Scavy 3 Replies Last reply Reply Quote 0
      • robmcc83
        robmcc83 @dokaponking last edited by
        @dokaponking your not going to get much help with that little information provided!
        • robmcc83
          robmcc83 @dokaponking last edited by robmcc83
          @dokaponking try reading this first
          Read me before posting
          Then I'm sure someone will be along to help but just to clarify recalbox 7.1.1 can run on pi4 because I use it and I'm sure many others do.
            Scavy Global moderator @dokaponking last edited by
            @dokaponking hello,
            I'm running a pi4 with recalbox 7.1.1... and it works. I may be a magician or a sorcerer ?
            • Chriskt78
              Chriskt78 last edited by Chriskt78
              are you using the right hdmi port, right aside usb C alimentation port?
              • Alexandre M
                Alexandre M @ben69 last edited by Alexandre M
                This post is deleted!
