    Before posting
    Important - Read me first
    before posting
    • digitaLumberjack
      digitaLumberjack Staff last edited by Pitch64
      Hi,
      Before you post your issue, make sure you do the following first:
      • Read the manual
      • Search the forum for an identical issue
      • Please do not re-post already solved topics. Just provide the link to the thread, or the tutorial, where the problem was solved.
      If none of the above helps, we'll need additional info to help you, just copy paste and fill the following :
      • Board model:
      • Recalbox version (build) :
      • Hardware (Micro SD, Power Supply, etc.):
      • Controller(s):
      If your problem is game related
      • Which Game:
      • Emulator used:
      • Is the problem reproducible (how):
      if you gamepad or your encoder usb related :
      • Plug your hardware directly into the usb ports of raspberry and ONLY YOUR GAMEPAD
      • Indicate how to reproduce the problem if possible
      1 Reply Last reply Reply Quote 4
      • Referenced by  Scavy Scavy
      • Referenced by  Nazgulh Nazgulh
      • Referenced by  McA McA
