    Trouble with splash screen (resolution ?)
    trouble splash
    2828
    • MadCow
      MadCow last edited by
      Hello everyone,
      I have a trouble regarding recalbox loading.
      Indeed, while recalbox is loading, there are funny splash screen videos before ES starts.
      It works well on my old 19" DVI screen (pluged with a HDMI to DVI plug converter), I can see splash screen (short videos).
      But it doesn't work properly with my other 19" LCD screens with only VGA plugs (pluged with a HDML to VGA plug converter).
      I tried with a viewsonic one and a acer one. Both have the same issue :
      • Screens are displaying recalbox black screens when power one (with a white blinking command cursor).
      • Then switch on splash screens (but no display) and screens monitors are displaying error messages. For Viewsonic : "Out of Range". For Acer : "Frequencies are not supported".
      • Then ES version and progress bar
      • Then Recalbox is up
      I'm using recalbox 7.1 on a Raspberry Pi 4, 64 GB SD Card.
      Do you have any idea of the reason of issues on splash screens ? Is it the result of a bad screen configuration in config.txt or recalbox.txt ?
      Thanks for your help.
      • ian57
        ian57 Staff @MadCow last edited by
        @MadCow hi there. In config.txt add :
        #video mode DMT
        hdmi_group=2
        #1280x1024 60
        hdmi_mode=35
        and in recalbox.conf
        global.videomode=DMT 35 HDMI
        should work
        • MadCow
          Thanks a lot @ian57 , but I've already did that.
          In fact, it's just during splash screen that my screens (plugged in VGA) are not able to display anything.
          In recalbox/ES, it's ok. I can see User Interface properly.
          Any other track or idea ?
          Thanks again for your help.
          • leahcim66
            leahcim66 last edited by
            Splash videos are in 1080p, that your screen doesn't support.
            Try to convert the videos in 720p (If you don't know haw to do this, I can send to you a video for testing) then put the files in share/bootvideos, and change in recalbox.conf this line :
            system.splash.select=custom
            Recalbox : Version 7.1 - Raspberry Pi4 4G, carte SD + clé USB 2 128 G
            Bartop : Version 7.1 - Rapberry Pi4 2G, carte SD + HDD USB3 2T
            MadCow 1 Reply Last reply Reply Quote 0
            • ian57
              @MadCow thats strange becaus I use viewsonic 19" screen with these parameter and everithing is working. BUT i use hdmi vga converter. I think we should look at dvi option 🙂
              did you try to add
              hdmi_drive=1 # force dvi
              and
              hdmi_force_hotplug=1
              • MadCow
                MadCow @leahcim66 last edited by
                @leahcim66 thanks for your proposal. Could you please share it ?
                Will try this.
                leahcim66 1 Reply Last reply Reply Quote 0
                • MadCow
                  MadCow @ian57 last edited by
                  @ian57 I will try also and let you know. Are you running with Recalbox 7.1 ?
                  Thanks for your great support ... 👍 👍 👍
                  • leahcim66
                    leahcim66 @MadCow last edited by leahcim66
                    @MadCow Try this one. If it works, I can provide a 70 videos pack.
                    https://we.tl/t-lurEYVPEjb
                    • MadCow
                      Thanks guys.
                      Custom videos works ! It's not the good format (my 19" screens are 1280x1024. 4:3 or 5:4 ratio ?) it's compressed, but can see the video on my both screens.
                      @ian57, could you please share the package you mentioned ?
                      Thanks for your great support.
                      • ian57
                        @MadCow which package ?
                        • leahcim66
                          leahcim66 @ian57 last edited by
                          @ian57 I think he means the package I metionned. Is it allowed to share boot videos here ?
                          • ian57
                            ian57 Staff @leahcim66 last edited by
                            @leahcim66 Yes I thinks so if there are not copyrigthed.
                            • leahcim66
                              Original bootvideos converted to 720p + 5 bootvideos I made myself.
                              https://we.tl/t-U1dz2uG5z6
                              • ian57
                                @leahcim66 I saw the "Universal" intro. Which soft did you use? I made this one using Blender : https://mega.nz/file/30kVECyb#_aefzs-WFwMmQfI8-U5OC4JoVKspfCbPZItVy5TYMZ8
                                • leahcim66
                                  Mine is from https://ivipid.com/
                                  • MadCow
                                    Many many thanks guys !
                                    Thanks for sharing your experience and tips !
