    Problem transferring big ROMs by using SMB
    big roms smb transferring
    • lhari84
      lhari84 last edited by lhari84
      Hi,
      Hope you are doing well and thanks to the team for great new Recalbox 7!
      I've just done a fresh installation to migrate from 6.1.1. Everything fine so far, except one small issue i want to report:
      When copying large ROMs to SD card using SMB share, process runs into an error immedately without transferring just 1 Byte. I have to skip affected file and Windows 10 (latest version) will continue with next, smaller ROMs without any proble. It seems problem occures with files > 1 GB only!
      I have no explanation for that, maybe you have an idea? In past I was able to copy same large ROMs by using SMB.
      It's not a big deal to me. As a workaround, I use SCP and here file transfer of files > 1 GB works like a charm.
      Just wanted to report it so it may be fixed if it's a general problem.
      You can find details of my config in signature. I'm using just the internal SD card, also for roms to keep the system stylish and compact. And the Box is connected by (stable) WiFi. So nothing special at all.
      Thanks!
      Pi 4:
      Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
      Pi Zero 2W:
      GPi Case 2W, Recalbox 9.0
        Zing Global moderator Translator @lhari84 last edited by
        @lhari84
        • https://forum.recalbox.com/topic/21821/smb-not-working-in-recalbox-v7-0
        • https://forum.recalbox.com/topic/21405/recalbox-7-0-smb-invalid-key-sharenetwork_smb1
        lhari84 1 Reply Last reply Reply Quote 0
        • lhari84
          lhari84 @Zing last edited by
          @Zing
          I'm not using an external SMB share for accessing content, like discussed in these 2 threads you linked.
          I got the problem when I want to copy a large file to Recalbox' own SMB share.
          Pi 4:
          Pi Zero 2W:
          • sroach
            sroach last edited by Zing
            @lhari84
            What is the error message?
              @lhari84 Have you ever tested on another computer to make sure it is not a Windows problem?
