    RPI3b - recablox 7.1.1 - FBNeo
    Your discoveries
    rpi3b recablox 7.1.1 fbneo
    4322
    • FrankieS
      FrankieS last edited by
      Hello, how are you?
      I have a problem with some games in FBneo.
      Games who play well in 6.1.1 and i dont know what happend in the new version, but i play so slow.
      I have this problems in red earth, and street fighter 3 (all versions).
      If it possible to change the core?
      It a good idea back to 6.1.1 in my rpi3b ?
      Thanks a lot!
        Hello @FrankieS
        fbneo core is 1.0.0x please upadate your romset with dat/xml file in /bios/fbneo and clrmamepro
        FrankieS 1 Reply Last reply Reply Quote 0
        • FrankieS
          FrankieS @acris last edited by
          @acris said in RPI3b - recablox 7.1.1 - FBNeo:
          1.0.0x
          Hello @acris , thanks !
          I have this files in /bios/fbneo
          ![0_1607456925521_6678f6d5-24b6-480a-841f-a252fa34cabd-image.png](Subiendo 100%)
          FinalBurn Neo (ClrMame Pro XML, Arcade only)
          FinalBurn Neo (ClrMame Pro XML, Neogeo only)
          i need to change something in this folder?
          the files have the 0.2.97.44 version.
          I install the clrmamepro program, but i dont know what i need to do with this.
          Thanks again, sorry for the questions.
          • airdream
            You can find a tutorial here :
            https://recalbox.gitbook.io/tutorials/utility/rom-management/clrmamepro-tutorial
            and here
            https://recalbox.gitbook.io/tutorials/utility/rom-management/clrmamepro-tutorial-how-to-check-your-roms-versions
            • barbudreadmon
              barbudreadmon @FrankieS last edited by barbudreadmon
              @FrankieS said in RPI3b - recablox 7.1.1 - FBNeo:
              Afaik you need at least a rpi3b+ to play CPS3 games with FB (minimum rpi4 if you want widescreen modes of sfiii and sfiii2), emulation requirements for that system were significantly b*mped in 2018 due to various fixes (was 6.1.1 using a version of FB that old ?). If you don't want to upgrade your hardware, maybe you can have those games playable again by overclocking your first-gen pi3 and/or using the frameskip core option.
              @acris @airdream slowness in a FBNeo game can't be related to bad romsets, bad romsets = won't launch at all
              Libretro developper :
              • FBAlpha FBNeo (Arcade)
              • Kronos (Sega Saturn/ST-V)
              • YabaSanshiro (Sega Saturn)
              FrankieS 1 Reply Last reply Reply Quote 1
              • FrankieS
                FrankieS @barbudreadmon last edited by
                @barbudreadmon
                Thank you !
                Yes, im test with update romset, and have same issue, slowness.
                In 6.1.1 this games works fine, i think that its a good idea back to this version, and i will change my hardware later :).
                Thank all of you ! this is a great cominity !
                @acris @airdream
                barbudreadmon 1 Reply Last reply Reply Quote 1
                • barbudreadmon
                  Well, i guess they seem to work fine if you don't see all the glitches, there are dozens of them, just 2 from sfiii :
                  alt text
                  See how the planks are bending at the end ? Actually they are supposed to be straight like this :
                  alt text
                  Another one :
                  alt text
                  See the blue background ? Actually a building is supposed to be shown in that background, like this :
                  alt text
                  I think all CPS3 games benefitted a lot from last 2 years fixes, tbh some of those games could be considered unplayable without those fixes : in jojo/jojoba the second player couldn't even see his combo bar.
                  • FrankieS
                    Hello @barbudreadmon
                    Yes its true, have glitches like you say.
                    But it was playable in rpi3b, today its so slow in 7.1.1, with a lot of sounds error.
                    I would like a better version for the 3b, i prefer latest version with good performance than new version with not playable games.
                    I really love recalbox, but i think 7.0 its too much for the rpi3b
                    • airdream
                      airdream Theme moderator last edited by airdream
                      i have just tested SFIII third strike with a rpi3B
                      With an overclock at 1300 Mhz i have fullspeed, or near
                      With an overclock at 1350 Mhz, i have also fullspeed, more constant, i think enough to play
                      this screenshot below was taken on rpi3b @1350Mhz
                      Shader : crt-nes-min enabled and Pixel Perfect enabled
                      FrankieS barbudreadmon 2 Replies Last reply Reply Quote 0
                      • FrankieS
                        FrankieS @airdream last edited by
                        @airdream said in RPI3b - recablox 7.1.1 - FBNeo:
                        Wow ! really ??
                        i have the same configuration @airdream with my 3b, 1300 mhz, but i dont have pixel perfect and no have shader.
                        I dont know what im doing bad, you put this rom in fbneo?
                        You are using 7.1.1?
                        Im trying with diferents roms too.
                        Thanks
                        • airdream
                          airdream Theme moderator last edited by acris
                          yes it on Fbneo on recalbox 7.1.1
                          do you have a lightening icon on top right of the screen? if yes your power supply is the issue !
                          MODERATE PLEASE RULE !
                          • airdream
                            also be sure to disabled "run in advance" or run ahead" (i dont't know the rigth term) in latency
                            It's located in Quickmenu > Latency
                            this option cost a lot of CPU ressources
                            also disabled Rewind fonction
                            • barbudreadmon
                              barbudreadmon @airdream last edited by
                              As a reminder, because some people might misinterpret this for a slowdown, cps3 games run at 59.59949Hz (that's another issue we fixed recently : in the past FB/MAME were running cps3 at 60Hz, which was too fast).
                              • FrankieS
                                My friend @airdream, you are awesome ! Thanks again!
                                this was the fu**ing problem !!
                                Im disable the rewind function and i can play perfect !
                                im disable latency too, in the retroarch menu.
                                Now i want to see where can distable it in all emulators, but yesss, is there in the rewind the problem.
                                Oh im so happy, thanks you too @barbudreadmon
                                • airdream
                                  airdream Theme moderator @FrankieS last edited by
                                  @FrankieS
                                  Great ! ! from the begening i dont't use rewind fonction, for me that's useless
                                  @barbudreadmon
                                  thanks also for the precision, and for the job to improve user experience
