    [7.1.1] Error 0x8007045d when copying roms to NES folder
    0x8007045d [7.1.1] copying nes roms
    1591
    • turn7
      turn7 last edited by turn7
      for any action in the nes folder I get an error
        @turn7
        you use share network to transfert your roms ?
        enough space on your storage ?
        turn7 1 Reply Last reply Reply Quote 0
        • turn7
          turn7 @acris last edited by
          @acris , yes, i use share network.
          Web interface loads endlessly on the Nintendo Entertainment System folder. More than 40GB of free space. Others copy to other parks roms without problems
          • ian57
            ian57 Staff @turn7 last edited by
            @turn7 Please do not use webmanager to upload roms, it is buggy ... use windows explorer instead.
            • turn7
              turn7 @ian57 last edited by
              @ian57,
              with windows explorer problem. Can you tell me how to get around it? Error 0x8007045d
                Zing Global moderator Translator @turn7 last edited by
                @turn7 This is not a Recalbox error.
                You either have your storage device corrupted, or you have a problem with Windows.
                • Try connecting your storage device to a computer and checking for errors.
                • Try to update Windows
                • If nothing works, search for the error code in the microsoft forum.
                turn7 Zing 2 Replies Last reply Reply Quote 0
                • turn7
                  turn7 @Zing last edited by
                  I connected the storage device to the computer, copying is in progress.
                  Connected over the network from different computers Windows 10 last update, windows 8.1 problem persists.
                  0x8007045d - problem means more often than not a storage device problem. But copying through the card reader goes fine.
                    Zing Global moderator Translator @Zing last edited by
                    @Zing
                    Did you do what I suggested?
