    Under voltage detected
    under voltage detected
    3679
    • Fefo81
      Fefo81 last edited by
      Hi guys,
      It’s a few weeks I noticed a message when I turn on the recalbox.
      The message said: under voltage detected (on the top left of the screen). On the same time, there is also an icon of a thunderbolt (on the top right of the screen).
      Is it an issue with the power supply?
      Cheers
      DacK 1 Reply Last reply Reply Quote 0
      • DacK
        DacK @Fefo81 last edited by
        @Fefo81 Most likely yes !
        Are you using a Nespi case with pi3 ? (it's a known issue with it)
        Anyway if not, it's probably your power supply indeed.
        Fefo81 1 Reply Last reply Reply Quote 0
        • Fefo81
          Fefo81 @DacK last edited by
          @DacK Thanks for your reply. My case is the flirc. So it’s a power supply issue. I suppose I need to replace it, right?
          • Pitch64
            Pitch64 Staff last edited by
            The power supply to use depends of the rpi used. It seems flirc have cases for rpi2/3/4. Which rpi are you using?
            You need to check if it's an official power supply. Having an official power supply should not display that thunderbolt.
            Next release? Soon™
            • Fefo81
              It’s not an official. I bought one with switch integrated.
                Zing Global moderator Translator @Fefo81 last edited by
                @Fefo81 The power supply does not necessarily have to be the official one, but needs to be 5V3A (the problem is the fake ones, which claim to be 5V3A, but they are not, so the official ones are recommended) (https://www.raspberrypi.org/documentation/configuration/warning-icons.md)
                • airdream
                  Your power supply is out ! !
                  Change it, choose a brand, a good 2,4A do the job
                  lot of 3A are false one, be care
                  • Fefo81
                    Thanks guys!
