    [Recalbox 7.0.1] HDMI not listed by xrandr
    [recalbox 7.0.1] hdmi listed xrandr
    1765
    • apellegr06
      apellegr06 last edited by
      Hello,
      I just install Recal box on an eeePC with NVIDIA Corporation GT218 [ION 2] video card.
      But this card is not listed with the command xrandr :
      xrandr
      Screen 0: minimum 8 x 8, current 1024 x 768, maximum 32767 x 32767
      LVDS1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 270mm x 150mm
      1366x768 60.03 +
      1280x720 59.74
      1024x768 60.00*
      1024x576 60.00 59.90 59.82
      960x540 60.00 59.63 59.82
      800x600 60.32 56.25
      864x486 60.00 59.92 59.57
      640x480 59.94
      720x405 59.51 60.00 58.99
      680x384 60.00
      640x360 59.84 59.32 60.00
      VGA1 connected (normal left inverted right x axis y axis)
      1280x1024 60.02 + 75.02
      1152x864 75.00
      1024x768 75.03 70.07 60.00
      832x624 74.55
      800x600 72.19 75.00 60.32 56.25
      640x480 75.00 72.81 66.67 59.94
      720x400 70.08
      VIRTUAL1 disconnected (normal left inverted right x axis y axis)
      And it's visible with :
      lspci | grep -e VGA -e 3D
      00:02.0 VGA compatible controller: Intel Corporation Atom Processor D4xx/D5xx/N4xx/N5xx Integrated Graphics Controller (rev 02)
      04:00.0 VGA compatible controller: NVIDIA Corporation GT218 [ION 2] (rev a2)
      So I can't output to HDMI.
      Have you an idea ?
      Thank you
      Alain
        Zing Global moderator Translator @apellegr06 last edited by
        @apellegr06 Read this:
        • https://recalbox.gitbook.io/tutorials/display-configuration/configure-an-external-display-x86-x86_64
        • https://forum.recalbox.com/topic/21480/recalbox-7-laptop-switch-external-screen-function-x86_64
        • https://forum.recalbox.com/topic/20469/cut-screen-initial-menu
        • apellegr06
          @Zing thank you, but HDMI doesn't appear in the xrandr command, so I think HDMI is not recognized and it's the problem.
            @apellegr06
            I understood that xrandr is not working as expected, that's why I cited the other posts, for you to use as a reference and test something.
            In this post for example (which I mentioned above), the user reports that he disabled the LVDS1 output, did you even read this? How about testing?
            https://forum.recalbox.com/topic/20469/cut-screen-initial-menu/8
            • Laban
              Laban last edited by
              Do you try to force xrand on VGA1 and disable LVDS1 in editing the xinitrc file ? (/etc/bin/x11/xinit)
              Borne d'arcade
              PC i7 3840MQ / Quadro K2000M / 32Go / SSD 500 Go
              Ecran iiyama ProLite E1980SD-B1
              Son sortie jack/amplificateur
              Joystick SANWA JLF-TP-8YT
              Bouton lumineux Cherry D44X
              GPI Case Rpi 0w sandisk ultra 128 Go
              MegaPi RPi 3b+ sandisk ultra 128 Go
              • Laban
                sorry the correct dir is /etc/X11/xinit/
                Borne d'arcade
