    Solved Recalbox 7 laptop switch external screen function x86_64
    recalbox laptop switch external function x8664
    • terri123
      terri123 last edited by
      Hello
      where can i find this option?
      in changelog is written
      "Add laptop switch external screen function only for x86_64 x86"
      On Recalbox 6.1.1 this was not a problem it automatic mirroed the screen to the HDMI Port. But now on Recalbox 7 it output a video signal until the boot video end and then nothing.
      I can activate the HDMI output by this command via SSH
      xrandr --output HDMI2 --mode 1920x1080 --primary --output eDP1 --off
      But i do not want to ssh into the Recalbox everytime i reboot.
      I tried to build a custom.sh in recalbox/share/system/ with this content
      #!/bin/bash
      echo 500 > /sys/class/backlight/intel_backlight/brightness
      time -p sleep 10
      After a reboot the screen brightness goes up but the video does not output to HDMI.
      Any one know a good solution for that?
      • terri123
        terri123 last edited by acris
        I found a way for me that it automatic change the display output when a HDMI cable is connectet and i do a reboot or a normal boot.
        I just changed something in this file
        /recalbox/share/system/recalbox.conf
        I changed this
        ## Prefered external screen retrieved from ssh : xrandr
        ;system.externalscreen.prefered=
        ## Force selected external screen to resolution ex : 1920x1080
        ;system.externalscreen.forceresolution=
        to this
        system.externalscreen.prefered=HDMI2
        system.externalscreen.forceresolution=1920x1080
        This is working nice for me.
        Maybe it will help someone
        But i could not find the switch function that is called in the changelog
        ("Add laptop switch external screen function only for x86_64 x86")
        • Zeke
          Zeke last edited by
          Thank you @terri123, I didn't have time to saerch that but I needed it to stop connecting and disconnecting my Monitors / TV 🙂
          PC x64 MSI X399 SLI Plus
          AMD Threadripper 1900X
          64GB Corsair Vengeance 3200Mhz
          EVGA GeForce GTX 1060 6GB
          Recalbox sur Western Digital Blue SSD 500Go M.2 (boitier USB-C 3.1 Gen.2)
          φ(k) ∝ At
          • davidb2111
            davidb2111 Staff last edited by
            Hi @terri123
            Nice trick! thanks for sharing.
            I'll take a look at the documentation and check for this.
            David
