    Not output video Recalbox 7- rpi4 in my TV
    output recalbox rpi4
    7
    19
    7954
    • gabo
      gabo last edited by
      Hello, my tv is hd (1360x768) connected with a raspberry pi 4 and I have problems with blackscreen (no signal), I had changed this parameters in config.txt file :
      uncomment to force a specific HDMI mode (this will force VGA)
      hdmi_group=2
      hdmi_mode=39
      And now I have solved the problem, but when I want to change to kodi I have the same problem with blackscreen (no signal video).
      thanks for yours answers!
      Zing zamalek89 2 Replies Last reply Reply Quote 0
        Hello
        rpi4 has 2 microhdmi port : hdmi 0 and hdmi 1
        do you try other hdmi port ?
        gabo 1 Reply Last reply Reply Quote 0
        • gabo
          gabo @acris last edited by
          @acris yes, both ports but the problem still go on.
            for kodi, @gabo
            what controller pad ? xbox360 ?
            turn off your controller, and with virtualgamepad on your smartphone, try again to launch kodi please.
            • gabo
              @acris thanks for your answer, I tried with virtual gamepad but it have the same problem: black screen or no signal.
              • gabo
                gabo @gabo last edited by
                @gabo I had updated to 7.0.1 but the problem is the same: black screen. Only changed was the boot plash screen.
                • key_deep2
                  key_deep2 last edited by
                  Hello, same problem installation v7.0.1 in RPI4 and no video signal. I have a signal if I start by disconnecting HDMI cable and then connecting it.
                    Zing Global moderator Translator @gabo last edited by
                    @gabo Only on Kodi do you have a black screen then?
                    Have you tried modifying kodi.videomode in Recalbox.conf?
                    @key_deep2 Apparently you need to configure the video output in the config.txt file as gabo quotes in the first post (but with the parameters corresponding to your screen). For more information, read:
                    • https://recalbox.gitbook.io/tutorials/display-configuration/complete-guide-on-video-configuration
                    • https://elinux.org/RPiconfig
                    gabo key_deep2 2 Replies Last reply Reply Quote 0
                    • gabo
                      gabo @Zing last edited by
                      @Zing yes, I have tried the kodi.videomode but the problem is the same. Thanks for your answer me
                      • key_deep2
                        key_deep2 @Zing last edited by
                        @Zing thanks for your answer, but i still have the same problem.
                        On a new Pi 3 Mod. B + installation with v7.0.1 (for pi3) no problem. Boots without modifying config.txt in DMT 81 (preferred resolution).
                        In a new Pi 4 installation with v7.0.1 (for pi4) the intro videos are seen, then black screen.
                        I can't get it to boot into DMT by modifying config.txt
                        hdmi_group = 2
                        hdmi_mode = 81
                        I only get it to boot by forcing VGA with hdmi_safe = 1 or with hdmi_group = 1
                        hdmi_group = x
                        I've tried different HDMI cables in case it was a cable problem.
                        • Laban
                          Laban last edited by
                          you can try this command to list all screens
                          DISPLAY=:0.0 xrandr
                          Edit /etc/bin/X11/xinit/xinitrc under the line # xrandr --output output_name --off the line with your TV entry
                          comment the line beginning by /usr/bin/externalscreen.sh &
                          For example, i have two screens LVDS-1 : my laptop screen and my TV identified by DP-0
                          I added this line
                          xrandr --output LVDS-1 --off --output DP-0 --mode 1920x1080
                          Then reboot your rpi4
                          Borne d'arcade
                          PC i7 3840MQ / Quadro K2000M / 32Go / SSD 500 Go
                          Ecran iiyama ProLite E1980SD-B1
                          Son sortie jack/amplificateur
                          Joystick SANWA JLF-TP-8YT
                          Bouton lumineux Cherry D44X
                          GPI Case Rpi 0w sandisk ultra 128 Go
                          MegaPi RPi 3b+ sandisk ultra 128 Go
                          key_deep2 1 Reply Last reply Reply Quote 1
                          • key_deep2
                            key_deep2 @Laban last edited by
                            @Laban Thanks for your answer
                            I have tried winSCP and PuTTy over SSH and it throws the same error
                            I can't find the directory you mention to me
                            • Pitch64
                              Pitch64 Staff last edited by
                              There is no xinitrc and xrandr on rpi... The issue seems to be on rpi, not on PC which have xinitrc and xrandr.
                              And xinitrc is on /etc/X11/xinit, there is no bin directory.
                              Next release? Soon™
                              • key_deep2
                                key_deep2 @Pitch64 last edited by
                                @Pitch64 It seems that way, my problem is that I give it two uses: in a room with a 22 "monitor for me and in the living room with the TV to play the children ..., I won't be able to use the pi4 for me. Thank you for your support
                                • zamalek89
                                  zamalek89 @gabo last edited by
                                  @gabo said in Not output video Recalbox 7- rpi4 in my TV:
                                  hdmi_group=2
                                  hdmi_mode=39
                                  I have the same problem. I am complete total noob. Any help?
                                  key_deep2 1 Reply Last reply Reply Quote 0
                                  • key_deep2
                                    key_deep2 @zamalek89 last edited by
                                    @zamalek89 I have been able to start Recalbox on a 1366x768 monitor in the following way:
                                    You put the microSD into the PC, open the "recalbox" unit, you will find several files, edit "config.txt" (notepad works).
                                    You change the lines:
                                    #hdmi_group = 1
                                    #hdmi_mode = 1
                                    by:
                                    hdmi_group = 2
                                    hdmi_mode = 39
                                    and save modifications. With these changes, it will start in 1360x768 resolution and recalbox will work without a problem, the bad thing is that you will not be able to switch to kodi, you will get a black screen.
                                    I have tried modifying kodi.videomode in the "recalbox.conf" file but have not succeeded in getting it into kodi.
                                    ** important ** that configuration only works for that monitor, if you start with that configuration on any TV it will not work
                                    zamalek89 1 Reply Last reply Reply Quote 0
                                    • zamalek89
                                      zamalek89 @key_deep2 last edited by
                                      @key_deep2 thank you so much that worked. Now i just need to get kodi to work
                                      • key_deep2
                                        key_deep2 @zamalek89 last edited by key_deep2
                                        @zamalek89 Try to enter kodi:
                                        • While in Recalbox, disconnect the HDMI cable.
                                        • Press X to enter kodi.
                                        • Wait a moment for it to enter kodi.
                                        • Connect the HDMI cable
                                          Not a solution, but it works
                                        • Laban
                                          @Laban said in Not output video Recalbox 7- rpi4 in my TV:
                                          sorry the file is in /etc/X11/xinit/
                                          Borne d'arcade
