    Bluetooth problem in RB 7.0
    bluetooth 7.0
    1563
    • mauline
      mauline last edited by
      I have serious problems with bluetooth in the new version. Which is a pity because I ordered two brand new bluetooth 8bitdo controllers that will arrive tomorrow 😞
      I have a logitech K480 keyboard and a wireless XBox 360 controller. Both worked without problems on a raspi 3B running RB 6.1.1.
      With RB 7.0 I'm no longer able to pair any of the two. For the XBox controller is says "pairing failed", for the keyboard it says "paired successfully" but the keyboard LED still blinks and the keyboard doesn't work.
      I tested this with RB 7.0 on a raspberry 3B and on a 4 (2GB). The behavour is identical for both boards.
      Any ideas?
        Hello @mauline
        @Bkg2k need your help :
        • Open SSH session
        • Tape : sdl2-jstest --list
        • Post result in your post or this post : https://forum.recalbox.com/topic/21497/recalbox-7-0-1-sur-les-rails/40
          thanks for your help.
        https://forum.recalbox.com/topic/21602/recalbox-7-0-bug-fix-list
        • mauline
          Done - for whatever it's worth (I don't speak french, so I have no idea what's going on in this thread).
          • mauline
            Just for the record: Disabling ertm solved the issue.
            bemandrill 1 Reply Last reply Reply Quote 0
            • bemandrill
              bemandrill @mauline last edited by bemandrill
              @mauline said in Bluetooth problem in RB 7.0:
              Disabling ertm
              Hello @mauline! I have a smiliar problem... how did you disble ertm? Thanks!
              EDIT:
              OK! I saw this post https://forum.recalbox.com/topic/17312/bluetooth-testers-wanted
              but when I reboot, it reposts N and not Y... 😞
                Zing Global moderator Translator @bemandrill last edited by
                @bemandrill To disable ertm it is easier to change the value of the line in recalbox.conf:
                controllers.bluetooth.ertm=1
                to
                controllers.bluetooth.ertm=0
