    Where is "rc.local" located?
    where rc.local located
    1917
    • yeeshkul
      yeeshkul last edited by yeeshkul
      I can't find the rc.local file.
      It should be in etc folder but it is not there.
      I was gonna see it the SafeShutdown.py is properly iniciated.
      This may be the reason the script doesn't work.
      Raspberry Pi 3 B+
      6.1.1-DragonBlaze
      Please help. Thank you.
      Here is what i have in the etc folder
      # ls /etc
      avahi                group                localtime            os-release           shadow
      bluetooth            hostname             logrotate.d          passwd               sixad.profile
      ctdb                 hosts                mke2fs.conf          profile              ssl
      dbus-1               init.d               modprobe.d           profile.d            sudoers.d
      default              inittab              modules.conf         protocols            timezone
      dhcpcd.conf          inittab.busybox      moonlight.conf       random-seed          udev
      dropbear             inputrc              mtab                 resolv.conf          usbmount
      emulationstation     issue                network              retroarch.cfg        wgetrc
      fonts                libnl                nsswitch.conf        samba                wireless-regdb
      fstab                lirc                 ntp.conf             services             wpa_supplicant.conf
        Rc.local not exist
        It s not raspbian
        • yeeshkul
          Thank you. So from which file the scripts are iniciated?
          I need to uninstall a script and want to do it properly.
          • ian57
            ian57 Staff last edited by
            @yeeshkul All starting scripts are in /etc/init.d, move the file you want to remove out of this directory and it will not started anymore
            yeeshkul 1 Reply Last reply Reply Quote 0
            • yeeshkul
              yeeshkul @ian57 last edited by
              @ian57 Excellent, thank you Ian.
              • yeeshkul
                One more question please - when i want to remove the file
                rm /etc/init.d/S99RetroFlag
                the system returns
                can't remove '/etc/init.d/S99RetroFlag': Read-only file system
                When i want to edit the file it says
                File '/etc/init.d/S99RetroFlag' is unwritable
                How to change mode of a file so it can be edited or erased please?
                • yeeshkul
                  yeeshkul @yeeshkul last edited by
                  @yeeshkul I think i got it
                  mount -o remount, rw /
                    Recalbox.conf
                    Is the file to enable shuutdown script.
