    Solved GPICase SNES default button configuration
    GamePad/GPIO/USB encoder
    gpicase snes default button
    • LuigiPuzo
      LuigiPuzo last edited by
      Hello
      First and foremost I'd like to thank the Recalbox team for the excellent work. It's my favorite forks of Emulationstation:
      I run it on my PC (x86 with a USB boot drive) and on my Raspberry Pi Zero GPiCase
      I am new here and I use the following setup:
      • Retroflag GPi Case;
      • Raspberry Pi Zero W
      • Recalbox 6.1.1 Dragonblaze;
      Everything works smoothly except!
      Within SNES emulator, the buttons are swapped again.
      In the Xbox game pad the button layout is as it shows:
      As well as on the Logitech:
      X Y A B
      Therefore, it's right that the Super Nintendo emulator swap the buttons X and Y and A and B.
      However, on the Retroflag GPi CASE:
      • On the Interface, the button scheme / layout is working perfectly
      • On the SNES Emulator however it's being "re-swapped" the button A is being mapped to the "south button" B to the "east button", X to the "west button" and Y to the "north button"
      • (Or in other words, A and B are swapped and X and Y are swapped)
      Is there a way to fix this so the buttons match the location of the buttons?
      I haven't yet searched for a solution in the configuration files as I believe someone else has already figured out where is the SNES config file and made the necessary adjustments.
      What I have done and did not work was:
      • Re-map the buttons manually on the menu;
      • Attempt to re-map the buttons for this emulator only;
        (It was taking so long I stopped trying)
      I'd be very glad if someone could help me.
      Thanks again,
      Luigi.
        paradadf Staff @LuigiPuzo last edited by
        @LuigiPuzo you can just remap the buttons in Emulationstation. Afaik retroflag controllers have the xbox controller name, thus they are not perfectly compatible with each other.
        LuigiPuzo 1 Reply Last reply Reply Quote 1
        • LuigiPuzo
          LuigiPuzo @paradadf last edited by
          @paradadf That worked now 🙂
          Thanks again.
          I'll try to find out "why it didn't work before". I think I made something wrong.
