    Custom Scripts not working anymore
    scripts anymore
    2445
    • lackyluuk
      Hi 🙂
      Since a long time I use some customs scripts in /etc/init.d for the startup & shutdown procedure. It worked with no problems.
      Recently I had to setup my recalbox from scratch (due to an upgrade error from 6.1 to 6.1.1) and somehow my scripts are not called anymore.
      If I log in via ssh and call the scripts manually, they work, but during startup they don't.
      I use the following structure for startup:
      start() {
      // Call a script which is located in /recalbox/scripts
      case "$1" in
      start)
      start
      esac
      Does somebody know a reason why this is not working anymore? Maybe I really miss a small thing somewhere..
      Thanks 🙂
      • lackyluuk
        Somebody of the team has an idea? Thank you 🙂
        • Michael Baudino
          Michael Baudino Staff last edited by
          Hi @lackyluuk,
          Could you please post the exact and complete script? I could have a look at it and try to reproduce.
          Could you also post the output of ls -l /etc/init.d/?
          Thanks in advance.
          • lackyluuk
            @Michael-Baudino Yes sure. I will post it this weekend when I am home. Thanks in advance 🙂
            • Michael Baudino
              Unrelated, but I love the NintendoRS linked in your signature: awesome work 😍
              Ooc, are you still using it?
              • lackyluuk
                lackyluuk Translator last edited by lackyluuk
                @Michael-Baudino
                Thanks 🙂
                Yes, I am still using it. But more to configure new themes or maintain the game lists. Recently i just finished Zelda - A link to the past 🙂
                Unfortunately I have to write from my smartphone since it tells me that my account is banned. Reason: insulting. Most probably I used the wrong password to often. But on the smartphone I am still logged in 😄
                Here is the content of the script which I am starting in /etc/init.d (S32StartFanAndVolumeControl.py)
                #!/usr/bin/python
                import subprocess
                try:
                    subprocess.Popen(["python","/recalbox/scripts/fanControl.py"])
                    subprocess.Popen(["python","/recalbox/scripts/volumeControl.py"])
                except KeyboardInterrupt:
                    print "Quit"
                Maybe this code is very bad, but it works when I run this script manually. And in the past (before 6.1.1) it also worked during startup.
                I also tried the structure with the start() case but also no success.
                ls -l /etc/init.d shows that the rights are the same as for the other scripts (-rwxr-xr-x l root root)
                Thank you for your help. Really appreciate 🙂
                • Michael Baudino
                  Thanks a lot, I'll try to reproduce 👍
                  Regarding your "insulting" ban, I have no idea what happen (unless you actually insulted someone, indeed 😅), but maybe @OyyoDams can help?
                    OyyoDams Staff @lackyluuk last edited by OyyoDams
                    @lackyluuk your account works so for sure it's not banned. Please double check your password.
                    lackyluuk 1 Reply Last reply Reply Quote 0
                    • lackyluuk
                      lackyluuk Translator @OyyoDams last edited by
                      @oyyodams yes, now it works. I tried using my nickname, but then it failed and told me I am banned. I used the email instead and you're right 🙂
                      @Michael-Baudino do you already had time to doublecheck the script issue? thanks 🙂
