    Solved Games not starting, WAIT read the whole post! Contoller to blame?
    Emulator Arcade/PC/Console
    starting wait read whole post
    1745
    • Orion5
      Orion5 last edited by
      Hi, thanks in advance for any help that you can offer. Running Version 6.1 on Raspberry Pi 3. I was able to pair both of my 8BitDo controllers (SN30 pro & N30 pro 2) pads successfully. They both move the dashboard screen and go to game selection no problem. But when I select a game it goes to black or the pac-man screen and freezes. I am certain it has something to do with the controllers as this does not take place when using my USB gamepads. I had a few pairing issues with the older versions but the games always played fine. Any advice?
      Einklinker paradadf 2 Replies Last reply Reply Quote 0
      • Einklinker
        Einklinker @Orion5 last edited by
        @orion5
        Started the game after around 45 sec. ?
        Orion5 1 Reply Last reply Reply Quote 0
          paradadf Staff @Orion5 last edited by
          @orion5 maybe the Start Mode of the controller you try to use isn’t the right one?
          https://github.com/recalbox/recalbox-os/wiki/8bitdo-on-recalbox-(EN)
          • Einklinker
            Einklinker last edited by
            My problem was the same for n30 pro 2.
            Before u connect start the controller with start+B
            • Orion5
              Orion5 @Einklinker last edited by
              This post is deleted!
              • Orion5
                @einklinker You ARE AWESOME!!!! Thank you! It was the ANDROID setting not the Windows! I could not find which to set when searching! Who would have thought that could change the load times! Thanks again to both of you for helping!
                • barbudreadmon
                  barbudreadmon @paradadf last edited by
                  @paradadf said in Games not starting, WAIT read the whole post! Contoller to blame?:
                  Exactly why i sold my SFC30, their mode stuff is totally annoying, especially since my (first generation) model was completely losing pairing if it was booted in another mode (idk if it is better now).
                  Libretro developper :
                  • FBAlpha FBNeo (Arcade)
                  • Kronos (Sega Saturn/ST-V)
                  • YabaSanshiro (Sega Saturn)
                    @orion5 am I not awesome too? I gave you the same answer before anyone else. 🙂
