    Apple IIGS
    Emulator Arcade/PC/Console
    apple iigs
    6
    10
    4712
    • gothrek
      gothrek last edited by
      Hi guys,
      someone try to play with Apple IIGS? i try all games and none start.
      Can u help me?
      Tks
      • rino
        rino last edited by
        Hello to all. I have the same problem as you. my roms are on an external hdd. I doubt that this is the problem. I had already asked if anyone was aware of the fact, but I have not yet received an answer. I await some clarification on the matter. A greeting.
          paradadf Staff @gothrek last edited by
          @gothrek @rino read the manual:
          https://forum.recalbox.com/topic/18941/apple2gs/8
          • Bkg2k
            Bkg2k Staff last edited by
            You must copy the required bios (either rom1 or rom3) in the bios folder, and name the bios file apple2gs.rom
            jpdonald 1 Reply Last reply Reply Quote 0
            • jpdonald
              jpdonald @Bkg2k last edited by jpdonald
              Sur Raspberry Pi 3.
              A mon avis, l'installation est OK, mais ça ne marche pas.
              En effet,
              slot 5 drive 1 (s5d1) lance les disquettes GS
              slot 6 drive 1 (s6d1) lance les disquettes AppleII
              slot 7 drive 1 (s7d1) lance le disque dur
              Sauf erreur de ma part, il semble que l'émulateur lance les disquettes en s7d1 donc ça ne marche pas. Lire le fichier gsplus.cfg créé (après le lancement d'une image) qui se trouve dans le dossier .config.
              Malheureusement impossible de démarrer une image de disque dur bootable avec le GSOS même en créant un fichier gsplus.cfg placé dans la liste de rom (???)
                Hello @jpdonald
                it's english forum, please use this language or create your own topic in french forum.
                • Bkg2k
                  There are 3 known issues with the appleIIGS emulator on Recalbox 6.1:
                  • Multidisk games are not loaded proprely (only the last is loaded in s7d1)
                  • Pads with no joysticks make the emulator not running
                  • BIOS info are missing in the manager and the bios/readme.txt
                  Everything is fixed in the soon-to-be-released fix version.
                  • rino
                    rino last edited by
                    thank you for your kind and quick reply. I followed your instructions and I also looked at the links and manuals you indicated.
                    unfortunately it still does not work.
                    i have a rasp with games on external hdd.
                    other tips?
                    thanks in the meantime
                    • gothrek
                      gothrek last edited by gothrek
                      i try but nothing,
                      all games dont works 😞
                      i try with rb3 and pcx64
                      • Bkg2k
                        Bkg2k Staff @gothrek last edited by
                        @gothrek Wait for the soon-to-be-released fix version.
