    Current state AdvanceMame with Recalbox 6.1
    Your recalbox
    current state advancemame recalbox 6.1
    4637
    • DreyMIX
      DreyMIX last edited by
      Hello,
      this below is a table made by me with the games that I currently have installed on my Recalbox 6.1 and that I use with the AdvanceMame emulator to take advantage of games that use lasergun, trackball, spinner and vector graphics.
      As you can see in the second column "Recalbox v18.07.13", most of the roms worked correctly and without any particular problems. I noticed the first slowdowns from the 6.0 version of Recalbox and continue to be there also in the Recalbox 6.1 (column 3).
      Can anyone confirm this?
      Thanks!
      AdvanceMame Emulator status
      ROMS RecalBox v18.07.13 RecalBox v6.0 & v6.1
      1000 Miglia: Great 1000 Miles Rally Perfect Perfect
      Arkanoid Perfect Perfect
      Arkanoid - Revenge Of Doh Perfect Perfect
      Arkanoid Returns Perfect Slow
      Asteroids Perfect Perfect
      Bad Lands Perfect Perfect
      Bang! Perfect Perfect
      Battle Zone Perfect Perfect
      Born To Fight Perfect Perfect
      Block Block Perfect Perfect
      Cabal Perfect Perfect
      Caliber 50 Perfect Perfect
      Cameltry Perfect Perfect
      Centipede Perfect Perfect
      Clay Pigeon Perfect Perfect
      Championship Sprint Perfect Slow
      Crystal Castles Perfect Perfect
      Crater Raider Perfect Perfect
      Dragon Gun Perfect Good in Menu - Slow in Game
      Discs Of Tron Perfect Perfect
      Danny Sullivan's Indy Heat Perfect Slow
      Gigas Perfect Perfect
      Goindol Perfect Perfect
      Gunbuster Perfect Slow
      Gravitar Perfect Good
      Irritating Maze, The Perfect Perfect
      Lethal Enforcers Perfect Good
      Lemmings Perfect Perfect
      Lethal Justice Good Good
      Lucky & Wild Perfect Slow
      Major Havoc Perfect Good
      Lunar Lander Perfect Perfect
      Line Of Fire / Bakudan Yarou Perfect Slow
      Marble Madness Perfect Perfect
      Missile Command Perfect Perfect
      N.y. Captor Perfect Good
      Night Stocker Perfect Perfect
      Off The Wall Perfect Perfect
      Operation Wolf Perfect Perfect
      Operation Wolf 3 Good Good
      Out Run Perfect Slow
      Pole Position Perfect Perfect
      Puzz Loop Perfect Slow
      Outfoxies, The Good Slow
      One Shot One Kill Perfect Perfect
      Point Blank Perfect Slow
      Police Trainer Perfect Perfect
      Prebillian Don't test Good
      Racing Hero Don't test Slow
      Revolution X Good Slow
      Road Blasters Perfect Good
      Rough Racer Don't test Slow
      Sharpshooter Perfect Perfect
      Space Gun Perfect Slow
      Star Trek Don't test Good
      Star Wars Good Slow
      Super Sprint Perfect Slow
      Tac/scan Perfect Good
      Tempest Perfect Slow
      Terminator 2 - Judgment Day Don't test Good
      Tournament Arkanoid Perfect Perfect
      Thunder Ceptor Don't test Slow
      Syvalion Perfect Perfect
      Under Fire Don't test Slow
      Wec Le Mans 24 Perfect Perfect
      Zombie Raid Perfect Perfect
      • GKM
        GKM last edited by
        Hello,
        I recently installed the Recalbox 6.1, starting from scratch. I own an Ultimarc SpinTrak and tried to run the "Out Run" roms on advmame and I can confirm that it runs very slow and with audio problems too. I have not tried the other roms because for the moment I am not interested, but when I have a moment, I can test some of the others and see if I find the same problems you have.
        Sorry for English, but I'm Italian.
        DreyMIX 1 Reply Last reply Reply Quote 0
        • DreyMIX
          DreyMIX @GKM last edited by
          @gkm Hello,
          so you too, the Outrun roms gives you problems of slowing down. It is already something and I feel relieved (at least it's not just my problem).
          It would be great if I could try another one of the ROMS listed above.
          But I also wanted to do another test. Install the Recalbox 6.1 on an 8 GB microSD card (I currently use a 64 GB microSD card), and try out the Outrun roms for example. Then install Recalbox 18.07.13 (hoping to find the image of the OS somewhere) on another microSD and try to start Outrun. Always using the AdvanceMame emulator. And let's see a little ...
          • DreyMIX
            Then I installed Recalbox 6.1 on a new micro SD (unfortunately I only have a 32 GB memory).
            First I performed a complete formatting using the software:
            https://www.sdcard.org/downloads/formatter/index.html
            Then as recommended by some guide, I started guiformat.exe completely deleted any remaining partitions:
            http://www.ridgecrop.demon.co.uk/index.htm?guiformat.htm
            So I uploaded the image on the microSD, started the system, connected to the Wifi, copied the ROMS for Advancemame and this is the result. Still slowdowns and audio problems.
            https://www.youtube.com/watch?v=_AQH0j2zex0
            • jorgemagana
              jorgemagana last edited by jorgemagana
              Most of your games in this list run without problem with mame2003 plus. Some of them needs some special configuration (I use a keyboard sometimes to enter some config screens), maybe this could help you:
              https://wiki.mamedev.org/index.php/FAQ:Games
              • glook
                glook last edited by
                vector games are definitively better on AdvanceMame (Asteroids, BattleZone...)
                GlOoK
                • DreyMIX
                  DreyMIX @jorgemagana last edited by
                  @jorgemagana I don't use mame2003 because as specified, for most of these ROMS I use 2 spinner. with mame2003 I never managed to make it work, while with advancemame it is very simple.
                  @glook yes also for this use advancemame.
                  Maybe they inadvertently did something that slowed Advancemame in some way. Before I used these ROMS without any problems.
                  • GKM
                    GKM last edited by
                    I also use Advancemame because I had problems configuring my SpinTrack on the mame2003. We hope they can solve the problems of slowing down. Thanks Dreymix for the test!
                    I unfortunately don't have any other microSD to do more tests. But as soon as I can I try with other ROMS.
                    • DreyMIX
                      DreyMIX last edited by DreyMIX
                      Good evening,
                      I was able to find and install again the old version of Recalbox v18.07.13, on the same 32 GB microSD where I had previously installed the Recalbox v6.1. I again formatted and reset the partition with the programs mentioned above.
                      I tried some games, from the table above, that with the Recalbox v6.1 gave the aforementioned slowdown problems. Instead with the v18.07.13 it has behaved very well.
                      The games have been started, as always, using the AdvanceMame emulator:
                      • Outrun
                      • Arkanoid Returns
                      • Championship Sprint
                      • Danny Sullivan's Indy Heat
                      • Dragon Gun
                      Video Youtube: Recalbox v18.07.13 Advancemame perfect!
                      https://www.youtube.com/watch?v=NW_sXq-uZUo
                      • GKM
                        GKM last edited by
                        I watched the video and actually something happened. Outrun as I see it behaved very well on the old version.
                        Is there a way to bring the same version of advmame back to the 6.1 recalbox?
                          paradadf Staff last edited by paradadf
                          Advancemame hasn’t been updated... that makes it difficult to track down what could be causing the slowdown. I’d suggest to try mame2003plus, as it has gotten many improvements in the regards that has been mentioned here.
                          GKM 1 Reply Last reply Reply Quote 0
                          • GKM
                            GKM @paradadf last edited by
                            @paradadf Hello,
                            I tried several times to configure my SpinTrak with mame2003plus, but I never succeeded. The fact is that Advancemame has the advantage of assigning the mouse ID, even if you attack 2 of them at the same time and all settings are made easily via configuration files. While on mame2003plus I never managed to configure two mice as separate devices. When I access the menu (TAB) of the mame and configure one, then the other takes the same actions. Even by assigning IDs to it through Retroarch I haven't solved.
                            It's not that I want to rush you, God forbid, but I hope that sooner or later you will take a look at what happened with the latest versions. It would really be a shame to lose some features of the Advancemame.
                            Thx 😉
                              paradadf Staff @GKM last edited by paradadf
                              @gkm not entirely sure this is exactly what you need, but in the following topic they talk a lot about analog input devices.
                              https://github.com/libretro/mame2003-plus-libretro/issues/399#issuecomment-457024703
                              It might be just a configuration thing... contacting the people there might give you insights as I really belive I've read spinners do work with mame2003plus.
                              See:
                              https://docs.libretro.com/library/mame2003_plus/#mouse-and-trackball-support
                              https://retropie.org.uk/forum/topic/17766/mame2003-plus-hundreds-of-new-games-improved-input-features-new-bugs-now-with-runahead-support/854
                              • DreyMIX
                                DreyMIX @paradadf last edited by
                                @paradadf Thanks,
                                as soon as I have some time, I'll see if I can set up at least one mame2003plus game using two spinners (hoping to succeed).
                                However, the intent of my post was also to make people understand what happened on the latest version of Recalbox. I don't know if you can tell the developers. As I repeat, there is no hurry, as long as it is made present.
                                Thanks!
                                  paradadf Staff @DreyMIX last edited by
                                  @dreymix the team is well aware of this post, don’t worry.
                                  • DreyMIX
                                    @paradadf Sorry for the delay. Thanks a lot 😉
