    Unsolved Moonlight on Recalbox 6.0 Not Working
    moonlight recalbox 6.0
    11
    32
    10018
      https://gitlab.com/recalbox/recalbox/merge_requests/669
      Fix 6.1 : https://gitlab.com/recalbox/recalbox/blob/master/RELEASE-NOTES.md
      micky49 1 Reply Last reply Reply Quote 0
      • micky49
        micky49 @acris last edited by
        @acris Yeah Thank you !
        Should we wait until 6.1 comes out to apply the patch?
        • micky49
          micky49 last edited by
          Is it possible for me to install this patch on my recalbox (Raspberry 3) ?
          • lmerckx
            lmerckx last edited by
            @micky49 As already answered above:
            It is possible but are you ready to recompile the Recalbox project ?
            Because you will need to do it ...
            The steps to follow are listed in this page: https://gitlab.com/recalbox/recalbox
            Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
            Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
            • allozavr
              allozavr last edited by
              released moonlight-embedded version 2.4.10
              • lmerckx
                @allozavr Thank you for the information
                You can follow the progress here: https://gitlab.com/recalbox/recalbox/merge_requests/723
                • Frostoman
                  Frostoman last edited by
                  Not working with GFE 3.12.0.84. Older Recalbox 18.07.13 works fine on another RPi. Please, give us opportunity to install older versions. Especially needed ZIP-archives compatible with NOOBS or PINN, to create multiboot SD-cards.
                  • lmerckx
                    lmerckx last edited by lmerckx
                    Ok, I'll explain differently:
                    In Recalbox 6.0, Moonlight doesn't work, with any version of GFE, due to a bug in the launcher.
                    This problem will be solved in version 6.1.
                    But, even when resolving this problem, the version of Moonlight used is not compatible with last versions of GFE.
                    So, Recalbox 6.1 also updates the version of Moonlight.
                    Conclusion: In 6.1, Moonlight will support all versions of GFE.
                    Frostoman 1 Reply Last reply Reply Quote 0
                    • Frostoman
                      Frostoman @lmerckx last edited by
                      @lmerckx said in Moonlight on Recalbox 6.0 Not Working:
                      It's understand. I just asking to give us opportunity to downgrade Recalbox to previous version, where Moonlight works fine, because for me this feature is critical and it's not working 😞
                      However, I'm already finds a way to restore my crashed SD-card with Libreelec 9.0.2 and Recalbox 18.07.13 installed, so don't pay attention to this message
                      • logan23
                        logan23 last edited by logan23
                        For those who wonder or ask the question :
                        If you connect another screen to your pc (with a dongle), it seems that Moonlight only cast the main one
                        https://github.com/moonlight-stream/moonlight-ios/issues/295
                        So , by this way, you should be able to use your computer on the second screen WHILE casting to recalbox on a RPI.
                        I haven't test it, tought.
                        Just in case....
                        • kdash9999
                          kdash9999 last edited by
                          Moonlight works with recalbox 6.1, thanks to all the team 🙂
                          lmerckx 1 Reply Last reply Reply Quote 0
                          • lmerckx
                            lmerckx @kdash9999 last edited by
                            @kdash9999 You're welcome ! 🙂
                            100.2k
