    FBA, Mame, NeoGeo, Snes & Megadrive Full screen games
    Emulator Arcade/PC/Console
    fba mame neogeo snes megadrive
    • WarWar
      WarWar last edited by
      Dear all, how to set up my recalbox to play FBA, Mame, NeoGeo, Snes & Megadrive games in full screen (stretched image) like for PSP games ? Thanks
      paradadf Zing 2 Replies Last reply Reply Quote 0
        paradadf Staff @WarWar last edited by
        @warwar check your tv settings. That‘s the easiest way.
        • WarWar
          Got always the overlays, no way to play with a stretched image
            voljega Banned @WarWar last edited by
            @warwar then remove yourvoverlays but I suppose you are not using official image ?
              Zing Global moderator Translator @WarWar last edited by
              @warwar If you are using an Rpi, you can change the videomode per emulator in the section:
              ------------ I - EMULATORS CHOICES -----------
              But if you are using a computer, x86 or x86_64, you will need to use the xrandr command.
              Read:
              https://forum.recalbox.com/topic/14398/menu-and-kodi-is-not-full-screen-on-old-netbook/4
              https://github.com/recalbox/recalbox-os/wiki/Change-display-resolution-on-x86---x86_64
              https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
              https://elinux.org/RPiconfig
