    WiFi on recalbox 4.1 is very unstable
    wifi recalbox 4.1 very unstable
    3891
    • AlfaJackal
      AlfaJackal last edited by
      Hi all,
      I have a massive issue with these two (compatible) wifi dongles:
      • TP-Link TL-WN725N
      • EDIMAX EW-7811UN
      The connection to my WiFi mostly aborts when I try to copy ROMs or several other (larger) files via Explorer or SFTP to recalbox. Sometimes recalbox also crashes - only switching off and on helps. In addition to this, it also does not automatically connect to WiFi after rebooting.
      If I connect an ethernet cable everything works perfectly. WiFi has no special characters.
      Any ideas to fix it? Or recommendations for a better WiFi dongle?
        Hello @AlfaJackal
        recalbox 4.1 is very old
        last version recalbox 18.07.13 : http://archive.recalbox.com/
        AlfaJackal 1 Reply Last reply Reply Quote 0
        • AlfaJackal
          AlfaJackal @acris last edited by
          @acris
          Ah, sorry, my fault: I have the newest version, just mixed the numbers.
            Zing Global moderator Translator @AlfaJackal last edited by
            @alfajackal You did not even say in what hardware you are having problems (Rp0,1,2,3,3 +? / PC? / Odroid?) ...
            Did you install the system yourself, or downloaded a ready-made image, or bought the system already recorded?
            Have you researched the forum to ensure that this is not a problem that already has a solution?
            https://forum.recalbox.com/tags/wifi
            • AlfaJackal
              AlfaJackal @Zing last edited by
              @zing I have a RPi2 with the Latest image from https://archive.recalbox.com/
              Unfortunately I did not find any proper solution when searching for WiFi in the forum. That is why I opened this thread.
              Before I switched to the latest release I had an old 4.0.0 installed and everything ran very well with my Edimax Wifi dongle.
                @alfajackal Sorry, try all of the procedures that have been suggested in this topic:
                https://forum.recalbox.com/topic/16393/wifi-is-not-working-on-pi-3b-or-pi-3b
                Have you tried on more than one different wi-fi (eg, a friend's house)?
                • AlfaJackal
                  AlfaJackal @Zing last edited by AlfaJackal
                  @zing said in WiFi on recalbox 4.1 is very unstable:
                  Thanks for your reply and providing me this thread, I also read before.
                  I am able to connect to my WiFi and two other different WiFi’s. None of the mentioned things in the other post applies except of „wifi.region=DE“. The connection is still unstable and breaks for e.g. when transferring ROMs.
                  I will try setting the region to DE later.
                    @alfajackal said in WiFi on recalbox 4.1 is very unstable:
                    • TP-Link TL-WN725N
                    • EDIMAX EW-7811UN
                    From what I've looked into the compatibility list, your WiFi Dongles are not the best:
                    https://github.com/recalbox/recalbox-os/wiki/Compatibility-(EN)#wifi-dongle
                    • AlfaJackal
                      Okay, changed wifi.region from US to DE; it already was enabled.
                      But I think I figured out the issue: It must be my Anker keyboard and mouse! It seems that these two (!) dongles newly make some problems (as already mentioned, it was never a problem in previous versions). After disconnecting the dongles the wifi is stable.
                        @alfajackal This is probably the case, the compatibility list warns that these dongles have this problem.
                        • AlfaJackal
                          I know! Because I added that! 😉
                          So literally I warned myself! Unfortunately I don’t have a time machine... 😂
