    Solved WiFi is not working on Pi 3B or Pi 3B+
    wifi pi3 pi3+ connection fail
    7
    17
    8425
    • darth_joghurt
      darth_joghurt last edited by
      Hi,
      I posted the same thread at the german forum two days ago. Since there was no response until today I try to reach more people at the international board. Sorry for double posting and for my bad english.
      Here is my problem:
      I can connect to the Internet via LAN but not via Wi-Fi. I've tried several ways on Pi3 and 3+.
      Here is what I've tested already :
      -SSID without special characters, once with spaces, once without spaces.
      -Password without special characters.
      -Registration via UI (SSID is found, connection is not possible).
      -Log in via Manager (saves the settings, but does not connect).
      -Login over the .conf (saves the attitudes, but does not connect) the semicolons before the SSID and the key removed thereby also, the Country code I put on DE, wifi enabled I set to 1.
      -The SSID on the router is visible, the security key is WPA2, the channel I have set to 8 testwise (normal would be auto, but that's not working too)
      So I hope I did not forget anything.
      After each change of settings, I rebooted the Pi, to no avail.
      I tested all settings with both Pi's (3b and 3b +).
      I do not know what else I can test. I hope you can help me.
      Btw, the WLAN chip works on both Pi's, because with other operating system everything works perfectly.
      OyyoDams Zing lhari84 3 Replies Last reply Reply Quote 0
        OyyoDams Staff @darth_joghurt last edited by
        @darth_joghurt what is your chip ?
        • darth_joghurt
          Sorry I don't understand your question. Is it possible that I have a different chip on my pi3 than on yours?
            @darth_joghurt sorry I thought you were using an external chip.
            In recalbox.conf, try to set wifi.region=DE
            • darth_joghurt
              No I'm using the internal chip.
              As I described in my opening post I already set the country code to DE.
              • darth_joghurt
                Do you need more information?
                  Zing Global moderator Translator @darth_joghurt last edited by
                  @darth_joghurt Which version of Recalbox are you using?
                  Have you set up the system yourself, or are you using a ready-made downloaded image from the internet?
                  Are you sure that the wifi did not connect? In my RPi3, sometimes when turning on the wifi shows as disconnected, but I can access the recalbox manager by the smartphone without any problem, you were only based on the information "disconnected" or tested?
                  • lhari84
                    lhari84 @darth_joghurt last edited by lhari84
                    @darth_joghurt
                    Hi, I had problems by configuring my 2,4 GHz WiFi using channel 12 and 13. At least with Pi3 B and latest Recalbox stable. Seems that Pi (or Recalbox?) does not support these channels.
                    Maybe this helps...
                    See also here at:
                    „WLAN-Autokanal inklusive Kanal 12/13“
                    https://service.avm.de/help/de/FRITZ-Box-Fon-WLAN-7490/015/hilfe_wlan_funkkanal
                    Pi 4:
                    Sony DualShock 4 (2nd gen), 8BitDo Pro 2, 8BitDo SF30 PRO, Retroflag SUPERPi 4 Case, Recalbox 9.0
                    Pi Zero 2W:
                    GPi Case 2W, Recalbox 9.0
                    • darth_joghurt
                      Hi, I used the latest stable version for the 3B and the Christmas-beta for the 3B+. I've set up the systems by myself, no pre-made images from the internet.
                      The connection was testet by trying to get access through the manager.
                      I've already changed the wifi channel to 8 but that didn't work too.
                        @darth_joghurt is the SSID is found, it means wifi works and your router is seen by Recalbox. Besides, for an unkwnown reason yet it cannot connect, and I bet it's password related, or maybe some security on your router side. Just WPA2 ? Not enterprise preshared key or something like that ?
                          @OyyoDams
                          Special caracter in wifi key ?
                          • darth_joghurt
                            No there are no special security settings on my router. My password is only numbers. All devices are allowed to connect to the router.
                              Scavy Global moderator @darth_joghurt last edited by
                              @darth_joghurt what is your wifi key encryption ?
                              • darth_joghurt
                                @Scavy what do you mean with encryption?
                                • darth_joghurt
                                  Hi guys, I have solved the problem. I thought I had the function "only allow known devices in the Wi-Fi" disabled and set to "allow all devices". Unfortunately, my router has not adopted the setting. After I changed it, everything worked
                                    @darth_joghurt great 🙂
                                    • peterbale
                                      peterbale Banned last edited by
                                      This post is deleted!
