    WIFI Dongle Recalbox
    wifi dongle recalbox
    2499
    • ishim7924
      ishim7924 last edited by
      Hello everyone, i've bought a wifi dongle Realtek 802.11n, but I don't know how to make it work with Recalbox. I've already checked and it's compatibl with Realbox, and even did the ''blacklist'' thing, but I don't know what to do with the installation of the wifi dongle. Someone can give any help?
      Jearon paradadf 2 Replies Last reply Reply Quote 0
      • Jearon
        Jearon @ishim7924 last edited by
        @ishim7924 hello you have to edit your config.txt file to disable the Pi's BT.
        Mmmh I did it but I do not remember the command line...
        Yees...
        dtoverlay=pi3-disable-bt
        Sorry for this it s time to go to work.
        RPi3 B + boîtier Nespicase + et Recalbox 9 - Manette Xbox360 filaire + clavier Rii mini i24T + noname type Snes
        ishim7924 1 Reply Last reply Reply Quote 0
          paradadf Staff @ishim7924 last edited by
          @ishim7924 just plug it in and it should be automatically be selected first as far as I know. If that isn’t the case, as suggested, blacklist the built in chip.
          • ishim7924
            ishim7924 @paradadf last edited by
            @paradadf but it doesn't need any previous installation like, in my computer? and can it work better with a usb to ethernet adapter?
            • ishim7924
              ishim7924 @Jearon last edited by
              @jearon why the bluetooth if it is wifi dongle?
              OyyoDams Jearon 2 Replies Last reply Reply Quote 0
                OyyoDams Staff @ishim7924 last edited by
                @ishim7924 dtoverlay=pi3-disable-wifi
                • Jearon
                  Jearon @ishim7924 last edited by Jearon
                  @ishim7924 Oooups! Sorry Ishim its nearly the same command 😄 as @OyyoDams said 😉
                  • ishim7924
                    ishim7924 @OyyoDams last edited by
                    @oyyodams so, doing that I can start using the wifi dongle. One last question, it only needs to plug in the dongle, or I need to click ''activate wifi'' on red ''configurations'' part? And, it will appear as ''disssconected'' always, or it will apear normally as ''connected''? Because i've seen other posts were people said it will appear as ''disconnected'', but that doesn't matter.
