    Trouble with Recalbox installation
    trouble recalbox installation
    • chasem
      chasem last edited by
      Hi all,
      New to this forum but have previously set up several Recalboxes hence my issues today proving extremely frustrating!
      I formatted a 32GB SD card , burned the Recalbox image onto it using Etcher, inserted the SD card into a Pi 3 B+, connected the Pi to the TV and switched the power on.
      The TV input reads Recorder 1 (Recalbox) and the little yellow lightning shows up in the top right hand corner, and that's it. Nothing happens. A blank screen. If memory serves, Recalbox / Emulation Station installs itself and then you're good to go. But nothing is happening.
      Any pointers much appreciated.
      Thank you
      joinski 1 Reply Last reply Reply Quote 0
      • joinski
        joinski @chasem last edited by
        @chasem
        Which version of Recalbox did you burn on your SD card?
        For Pi3B+ only this test-version is working:
        https://forum.recalbox.com/topic/15010/testers-wanted-major-system-upgrade-pi3b-kodi-17-and-much-more
        • chasem
          Thanks for your reply. I downloaded the burnable image for Raspberry Pi 3 on this page:
          https://archive.recalbox.com
          I take it this isn't the right one?
            OyyoDams Staff @chasem last edited by
            @chasem nope, you have to download the beta version for 3b+
            chasem 1 Reply Last reply Reply Quote 1
            • chasem
              chasem @OyyoDams last edited by
              @oyyodams
              Thanks! Any idea when the finished product will be ready?
              @oyyodams said in Trouble with Recalbox installation:
