    How to remove Recalbox from an SD card
    remove recalbox card
    • Diego Fernández
      Diego Fernández last edited by
      Hello everyone! I have an issue with a micro SD card with recalbox 4.0 for rpi3, i want to delete it to make a fresh install, but Windows identifies the SD as Read Only, i checked the lock switch and it's unlocked, i tried using diskpart, using the command "attributes disc clear readonly" but it does nothing, tried with SD Formatter and nothing, so i don't know what to do.
      Any help will be preciated
      Thx!
      OyyoDams Gaetan 2 Replies Last reply Reply Quote 0
        OyyoDams Staff @Diego Fernández last edited by
        @diego-fernández try another SD card reader, and if that doesn't solve the issue, your SD may be dead.
        Diego Fernández 1 Reply Last reply Reply Quote 0
        • Gaetan
          Gaetan Theme moderator @Diego Fernández last edited by Gaetan
          @diego-fernández I recently had this problem. As @OyyoDams said, I tried to use another micro sd adaptator and it worked.
          Give it a try 😉
          • Diego Fernández
            Diego Fernández @OyyoDams last edited by
            @oyyodams I used two sd adapters and both did the same, the weird thing is that recalbox works fine, except that some configs doesn't save, that's why i find odd that i can't format the sd.
            Well i have to buy another sd card
            Thanks for your help!
              Zing Global moderator Translator @Diego Fernández last edited by
              @diego-fernández I've seen some users report that they were able to format an SD card (which was supposed to be defective) by the Android smartphone, and it worked after that. I've never done that, but it's a last try, before giving up completely on the card. If it does not work, it's definitely defective.
