    SNEs usb controller doesn't work on most SNES games
    snes usb doesnt
    2441
    • charlie84
      charlie84 last edited by
      Hi, I have configured SNES-like usb controllers and they don't work on most games of SNES. They seem to work on other systems (MegaDrive, NES...) and even in some SNES games but most of them do not work. Do you know what could be?
      Thanks
      • charlie84
        Help please
        • Gaetan
          Gaetan Theme moderator @charlie84 last edited by
          @carlos-lópez-de-toro from my point of view, I would reinstall Recalbox and give it a new try.
          I really don't see a reason of this behaviour.
          If you can't or don't want to reinstall, you can post a support archive here, waiting for one dev to help you.
          • Dragu
            Dragu Banned last edited by
            @Carlos-López-de-Toro
            and the "SNES-like usb controllers" have sure a name. If you dont find, put a photo.
              Try, others cores
              games ?
              • charlie84
                Dear all, thank you for the help. Here you go the picture [0_1536344563246_IMG_20180907_202025.jpg . It's a controller bought on Aliexpress or one of those places.
                Castlevania works, Dragon Ball z 2 works, Final fight works, Sunser rider works... but at least all bomberman's I have don't work.
                • Dragu
                  @charlie84
                  Like @acris was proposing, try other core in Snes, Hotkey + Select on game selection menu, emulator - Libretro core - snes9x_next.
                  • charlie84
                    Thanks! Snes9x worked, but it seems it's less performant, maybe tuning some option can improve it. Anyway, thank you! I am able to play now 🙂
                    • Dragu
                      @charlie84
                      I was asking you for photo, because I remember guy in the video was having also this problems
                      https://www.youtube.com/watch?v=UkM77NoXDgc
                      charlie84 1 Reply Last reply Reply Quote 0
                      • charlie84
                        charlie84 @Dragu last edited by
                        @dragu said in SNEs usb controller doesn't work on most SNES games:
                        @charlie84
                        Actually it seems to be the same...
