Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...)
To those who have difficulties to save Recalbox configuration on external devices, please can you post more information:
- What is not saved?
- Configured from the Webmanager or from EmulationStation (or both)?
- What's the file format of your external device (Fat32, exFat, other, ...)?
A ceux qui ont des difficulté à sauver la configuration de Recalbox sur les disques/clefs externes, pouvez vous donner des informations plus précises:
- Quelle config n'est pas sauvée?
- Configuré par le Webmanager ou par EmulationStation (ou les deux) ?
- Quel est le système de fichier du périphérique USB utilisé (Fat32, exFat, autre, ...)?
@bkg2k
Hi, I'm also having the same problem @tylerdurden67
its I change the name of the system, the recalbox recognizes all roms, however I can not execute any of them. none works.
I'm also trying to split the FBA_LIBRETO into 3 CPS1 CPS1 and CPS3 systems.if I leave everyone with the name fba_libreto, only 1 system is recognized and runs the roms perfectly, but if I rename the systems for CPS1, cps2 and cps3, all 3 are recognized, but none are executed.
Could you help me with this?
@lauderneto As already told to @TylerDurden67 can you please respect this subject ?
Your custom modifications and your inability to do them correctly as absolutely nothing to do with the subject of the beta and its bug.Open a dedicated thread if you want help.
@voljega said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
Open a dedicated thread if you want helpsorry, I thought this was a bug, because in previous versions it works normally. as I now have a PI3 +, I can only use this beta. I thought I was doing something wrong, but I saw a colleague from the forum claim the same problem.
I will not bother you anymore
Hello
I'm using the beta on a raspi3B+ ,and it's stable but...- i can't associated my PS4 controller
- arcade stick is unavalaible
- the overclocking is at 1375 max
- i can't (or i don't understand) put overlays
It's a great ES , thanks !!!!!!!
Good evening everyone,
I just made a new test theme on the Beta version of Christmas. Same problem the other day. After rebooting emulationstation does not restart, black screen ...
I had to delete the theme folder (with Filezilla) then I restart. Strange display at the restart simply corrected in the menu by selecting the default theme.
Here is the link for the support file (recalbox-support-20190103223044.tar.gz) before fixing the incident: http://dl.free.fr/n5lVT0TIG
I have not encountered any problems with the following tests: Shaders & overlays and text file configuration of Mupen64plus for an original N64 controller (with raphnet adapter).Good luck, I hope it will help a little ;-)
Configuration : Pi3+ avec PIDRIVE. Manette Logitech. BETA XMAS. Le PIDRIVE est partagé avec un PI3 classique avec la dernière version stable.
2 problèmes rencontrés en qq minutes :
- Emulateur Dreamcast ne fonctionne plus : affichage écran noir au lancement et retour au menu. Je n'avais pas de problème sur la version précédente de la BETA (aucun changement dans le contenu du PIDRIVE)
- EmulationStation : Ecran menu option/mettre à jour les listes des jeux => cela recharge bien les nouvelles roms mais plus de sauvegarde du gamelist.xml au préalable. Je lance la nouvelle rom, je joue et je sors. Je relance ce menu, idem + génération d'un fichier XML sans noeud avec le nom gamelist.xml.xml
Par contre, mon émulateur PSP fonctionne maintenant, ce qui n'était pas le cas de la précédente BETA. Pas de problème de sauvegarde de configuration avec mon PIDRIVE (format ext4)
You don't have necessary to create a new system. How i work with recalbox :
- fba folder : CPS, CPS2 et CPS3 system
- neogeo : all fba roms with neogeo.zip
- fba_libretro : another roms including pgm.zip
I hope that help you. bye
@nordicpower said in Testers wanted: major system upgrade (Pi3b+, KODI 17 and much more ...):
Vraiment pas une bonne idée ça, tu vas au devant des ennuis, rien ne dit que le recalbox.conf par défaut est le même pour les deux versions par exemple
Sur la dernière beta avec un pi3 b+ :
J'ai perdu au bout de quelques jours d'utilisation, le bon fonctionnement du script system.power.switch=PIN356ONOFFRESET avec un boitier mega pi (avec safe shutdown)
Le bouton on/off ne fait plus rien , le bouton reset lui fonctionne correctement.
Dans le recalbox.conf la ligne du power.switch est dupliqué 9fois (c'est un problème récurrent sur toutes les betas).
J'ai déjà eu ce problème sur les anciennes betas et n'ai pas trouvé de solution.J'ai eu beaucoup de mal à appairer les manettes 8bitdo (SFC30pro et Nes30pro), (les manettes sont détecté mais l'apparaige échouait) après pas mal de redémarrage de la recalbox, c'est passé à un moment.
Via la partie web impossible de sauvegarder les modifications de configurations lorsqu'une clef wifi contient des caractères spéciaux (message d'erreur, impossible de sauvegarder la configuration, testé avec une clef renseigné dans wifi2)
Impossible de créer une archive du support avec un navigateur web (Edge)car rien n'est proposé au téléchargement et aucune archive visible dans le dossier save.
Ci joint l'archive de support crée via putty : http://dl.free.fr/hZ82scqVj
Autre question, pourquoi l'émulateur par défaut de la megadrive et de la mastersystem est picodrive et pas GenesisplusGX qui reste beaucoup plus performant ( picodrive a des problèmes de sons sur pas mal de roms ) ?
Picodrive est par defaut car il est fonctionnel sur toutes les boards notamment moins puissantes que rpi3 ou genesis posé des problemes
Perso sur ttes les roms testés sur picodrive jai pas eu de probleme de son
@jass76 Ca me fous la rage, d'essayé des milliers de fois, pour finir en ecran noir et led rouge! A chaque fois après etcher, ou win32, il me dit 1 ou 2 fois, formater partition machin, j'annule, et je lance le raspberry et rien....
@alex592 Il ne sert a rien de flasher X fois si le resultat est le même ;)
Il est possible que ta SD soit abimée. Un test avec une autre SD serait plus constructif.
Et pour la Xieme fois:- Formatter une SD avant de la flasher avec Etcher ne sert strictement à rien hormis à l'user un peu plus. Le flash écrase tout ce qu'il y a sur la SD, y compris les partitions et les formattages précédents.
- Il est normal que windows demande de formatter après le flash, puisque le flash va écrire une partition avec un systeme de fichier non reconnu par windows. Bien entendu, il ne faut surtout pas formatter :)
@acris
Ne pas tenir compte de ce que j'ai écrit sur picodrive, il semblerait que ce soit genesisplus qui bug/"ajoute" des sons parasites sur certaines roms (outrun master system), que je prenais pour des sons d'ambiance manquants.
Hi,
I was playing around with the christmas beta on my RPI3B+, trying to load some kodi addons, I got the error with twitch:
ffmpeg[5ECEE3E0]: https protocol not found, recompile FFmpeg with openssl, gnutls or securetransport enabledNot sure if I missed something somewhere.
@voljega Pour l'instant, le seul effet de bord est sur la gestion des mises à jour que j'ai désactivé. Cela fonctionne plutôt bien pour mon utilisation.
Salut,
Problèmes rencontrés avec RPI3B+ et version Xmas:- Roms Dreamcast ne fonctionnent plus (fonctionnaient avec la version Beta précédente)
- Scrapping ne marche plus
- un fichier gamelist.xml.xml (double extension) apparait dans les dossiers roms (le fichier est rempli avec beaucoup de ligne vides puis quelques noeuds xml pour finir.
Merci pour votre boulot. Vivement la stable !
Bonjour à tous
je tente de configurer la NeoGeo CD sur la version Beta sortie à Noël.
J'ai créé un dossier neogeocd dans le dossier Roms, ai placé les bios neogeo.zip et neocdz.zip dans le dossier bios.
Rien n'est détecté. Mes jeux sont au format chd, aussi je me pose la question : est-ce que mon paramétrage est foireux ou alors est-ce le format de fichiers qui n'est pas bon ?
Quelqu'un pourrait-il me donner quelques pistes ?
Merci d'avance et meilleurs voeux à tous :)
Hi, and thanks a lot for this awesome work.
Here's my configuration :
Board : PI 3B+
Version : 2018.12.24.Christmas.Beta
SSD : 8GB
HDD : 1TB
AC : Official Raspi (2.5a) - I never have any lightning.Bugs reported so far :
- Impossible to connect a Xbox One V2 (BT compatible) gamepad. It loads infinitely, and the pad stops itselfs. The system stays stuck on trying to connect.
- Impossible to connect a PS4 gamepad. It loads then says "impossible to connect". This pads works without any problem on my Pi 3B with the stable version of July.
- System freezes when I try to delete a game from the interface.
- If I delete games coming with the release (i.e. DOOM), it comes back after a while. I tried through network and through the interface
- Sometime, crashes when I unplug a pad connected with USB.
- The bug on Nes stills here. I need to modify the retroarch config file to avoid cropped image.
Hope this will help ! Thanks again !
Hi,
Board PI 3B+
i'm trying to upload dreamcast bios
with md5sum on recalbox
e10c53c2f8b90bab96ead2d368858623 dc_boot.bin
0a93f7940c455905bea6e392dfde92a4 dc_flash.binbut when i'm connecting on web interface for bios management I have
dc_boot.bin e10c53c2f8b90bab96ead2d368858623 with ok tick
and
dc_flash.bin d6e11a23f1fa01cddb5dfccf7e4cc8d7 with wrong tickthis is not the same md5 but the dc_flash is good, i made a md5 before uploading it to recalbox and after and it's still 0a93f7940c455905bea6e392dfde92a4. Maybe a false positive on web interface ?
But games doesn't startthanks !
