    Can't connect Recalbox to Wifi
    cant connect recalbox wifi
    6827
    • motenai79
      motenai79 last edited by
      Hello all,
      I'm running Recalbox on a RPi3, current version 18.06.27.
      Yesterday it seemed to be connecting fine to my Wifi, but today, not so much.
      Actually, it did, this morning for a few minutes but then, in the middle of the download of the latest version (about 45%), it froze.
      It froze during the download, not the installation.
      I had to shut it down violently as no key seemed to work.
      I expect this violent shut down to be the source of my issue, gotta be honest here...
      My network is fine (SSID visible and all). Proof is that I run 2 other recalboxes on RPi3 (same material config) and I could update them with no problem.
      But the one in my bartop won't connect anymore (neither wifi nor cable by the way)
      Here is what I tried and failed to work :
      • Removing and re-entering SSID + Password through keyboard,
      • Entering SSID + Password for another wifi network (access point using my cell phone)
      • Connected a network cable (and disabling wifi on recalbox),
      • Tested the micro SD card on a RPi 3 on which I could upgrade (to check if the RPi 3 was the cause of the issue, no change)
      Obviously the SSH remote connection won't work either as the recalbox is not connected.
      I don't have any error message, when I turn off and on the wifi, it simply says "WIFI activé", but nothing happens.
      I'm a bit out of options now, I searched on the forum but nothing seem to fit.
      Is there a way to check the recalbox.conf when you're not connected through SSH ?
      Any advice would be more than welcome.
      Thanks for your help
      Philippe
      PS: I'd like to avoid duplicating the micro SD from another RPi if possible (you know, the saves, favorites and all are different).
        Substring @motenai79 last edited by
        @motenai79 please first upgrade to 18.07.13, there is a fix regarding wifi
        motenai79 1 Reply Last reply Reply Quote 0
        • motenai79
          motenai79 @Substring last edited by motenai79
          @substring
          Hello,
          Thanks for your response.
          Tha's actually wht I wanted to do, but how can I upgrade to 18.07.13 without connection ?
          I usually connect and Recalbox detects that a new version is available.
          But here, it won't connect.
          Is there a way to upgrade off-line ? (by downloading an upgrade file and install it manually ?
            @motenai79 go to the network menu, disable wifi, press A, again network menu, reenable wifi
            • motenai79
              @substring
              Hello,
              Yes, I did that already several times (and tried on another wifi network).
              Even with the wifi enabled, nothing happens.
              I just et the message "wifi activé" and nothing else happens, stays disconnected.
              What I don't get is that even if I disconnect the wifi and plug in a network cable, it won't connect either.
              All network activity seems to be blocked or disabled somehow.
                OyyoDams Staff @motenai79 last edited by
                @motenai79 well if it doesn't work with an ethernet cable, it's not a wifi related issue. Please check your network connectivity (firewall or ISP).
                • motenai79
                  motenai79 @OyyoDams last edited by motenai79
                  @oyyodams
                  Hello,
                  Thank you for your response, unfortunately, it's not that either.
                  As it works with my other recalboxes and all other devices (phone, consoles, etc.), it's not a firewall nor a ISP issue (I rebooted my Freebox just in case).
                  Didn't change a thing.
                  Could it be a conflict of IP address ?
                  I'll try to disconnect all the devices than can book an IP address and give it another try, we never know...
                  Edit: I just did all that, disconnected the consoles, PC, Google home, tablets, phones, etc, still the same. Even if I disable and re-enable the wifi, I get the message "wifi activé" and that's it, nothing happens, no IP address assigned.
                  Is there a way to check the recalbox.conf file to see if there is something wrong (considering of course that it's not possible to access via SSH) ?
                  It's weird when you consider that it did connect yesterday and this morning also, until it froze at 45% of the download of the upgrade.
                    @motenai79 toutes les chances que le problème soit chez toi ...
                    • motenai79
                      @substring
                      En fait je suis à court d'idées ou de pistes de résolution. Je suis ouvert à tout qui peut m'aider à comprendre et résoudre ce comportement bizarre de mon Recalbox.
                      Y a-t-il un moyen de faire un update à la mano, d'extraire un dump ou éventuellement d'avoir accès au fichier config pour voir si rien n'est bloqué côté connexion, autrement qu'en ssh ?
                      Au pire, je peux la jouer violent et dupliquer le contenu d'une autre carte SD dessus mais c'est dommage (de pas savoir ou de comprendre d'où vient le souci).
                      Après, j'ai cru comprendre que tu étais en vacances en ce moment (vu sur un autre post), ne passez pas des heures au carré sur mon cas, vous y avez déjà passé assez de temps (encore merci au passage pour ça à toi et @OyyoDams ).
                      Je vais faire deux/trois autres tests et au pire je duplique depuis mon autre recalbox qui marche bien avec la mise à jour et roule, tant pis, je n'en mourrai pas.
                      Encore merci beaucoup pour votre aide et votre réactivité en tout cas !
                        @motenai79 https://github.com/recalbox/recalbox-os/wiki/accès-root-sur-Terminal--(FR)
                        Accès direct Sur l'interface emulationstation, appuyez sur F4 pour quitter, puis sur Alt + F2 pour obtenir un terminal et utilisez les mêmes identifiants que ci-dessus.
                        Si t'es un guru de la ligne de commande tu peux t'amuser...
                        • motenai79
                          @oyyodams
                          Oui, j'ai vu ça. Mais non, malheureusement, je ne suis pas un guru de la ligne de commande non.
                          J'ai testé, et vite vu que je savais pas faire grand chose.
                          Je vais donc m'en tenir à ma dernière solution.
                          Encore merci !
                            @motenai79 dans réseau ça va être difficile de mettre à jour. Mais sinon oui, pour le moment c'est encore possible de mettre à jour manuellement en téléchargeant certains fichiers au bon endroit
                            • motenai79
                              @substring
                              Merci encore pour ta réponse.
                              Je suis en train de finaliser le clonage d'un autre Recalbox qui tourne bien.
                              J'aurai un peu de conf à refaire genre core map, résolution, ce genre de truc pour l'adapter au bartop (rien de bien lourd) mais au moins ce sera à jour et je me prendrai plus la tête.
                              Encore merci et j'espère ne pas avoir entaché tes vacances !
                                @motenai79 ah non pas entachées du tout 😉
                                • eddrik
                                  eddrik last edited by
                                  Je ne sais pas si tu as eu ta réponse, mais il ne faut pas oublier que ton clavier sera par défaut en mode QWERTY, il faut y songer quand tu entre ton mot de passe.
