    Recalbox on laptop MSI-GX623 - Emulators start into blackscreen
    Emulator Arcade/PC/Console
    recalbox laptop msi-gx623 start blackscreen
    3001
    • ehfred
      ehfred last edited by
      Dear Recalbox Community,
      When I start any emulator - I get a blackscreen. The monitor I have has the following properties:
      Aspect Ratio: 16:10
      Resolution:1440x900
      When I use tvservice. Independent of what command I use, I get the output:
      tvservice "code":1, "width":1280, "height":800
      I tried a variety of "global.videomode=XXX". Different "CEA X HDMI" modes and all the "DMT X HDMI" modes that should be the resolution of 1440x900 and 1280x800.
      I also changed the Aspect Ratio from "auto" to "16/10" on all the modes.
      What should I do?
      Best,
      ehfred
        Zing Global moderator Translator @ehfred last edited by
        @ehfred Have you tried editing the recalbox.conf file?
        You claim that you tested several videomodes but did not specify which ones ...
        Try to edit the recalbox.conf, line:
        global.videomode = CEA 4 HDMI
        Change to:
        global.videomode = default
        And test on some emulator, like the SNES, or any other (other than the Dreamcast or N64 - as these have specific configurations of videomode, and the configuration must be changed in their respective configurations).
        Keep the Aspect Ratio "auto".
        ehfred 1 Reply Last reply Reply Quote 0
        • ehfred
          ehfred @Zing last edited by
          @zing I did exactly that and it boggles me that the booting and the menu works perfectly fine - so it doesn't really make sense that it wouldn't work with default video mode since it means as far as I understand that the resolution isn't changed. I also tested everything with and without aspect ratio "auto".
            videomode and tvservice stuff is pi only
            • ehfred
              ehfred @Substring last edited by
              @substring Wow. So that's good to know. Thank you! All the time spent was wasted ^^ Do you have any insight on what might help?
                Substring @ehfred last edited by
                @ehfred need a support archive 😉
                • ehfred
                  ehfred last edited by ehfred
                  This post is deleted!
                  • ehfred
                    @substring I hope this is what you want:
                    https://drive.google.com/file/d/1zp9DOjiTQaOxAgRwMecYhbJB6d8Qi1Pf/view?usp=sharing
                    Thanks a lot in advance, my friend!
                      OyyoDams Staff @ehfred last edited by
                      @ehfred this is a batocera archive. We're Recalbox, not batocera. Please go to batocera support, or install Recalbox.
