    Solved Menu and Kodi is not full screen on old netbook
    kodi full old netbook
    13304
    • ash1390
      ash1390 last edited by
      hi... i had an old asus netbook:
      https://www.asus.com/Laptops/Eee_PC_1001PXD/
      with broken screen and heat problem... i fixed it and decided to make it retro box and connect it to TV.
      alt text
      i installed Lubuntu 18.04 on it's main HDD and recalbox into and SD card.
      everything works fine i can get fullscreen Lubuntu and boot from SD card for recalbox.
      it can run games perfectly till Ps1 (45 FPS on PS1 no sound).
      i connected the laptop via the VGA output to the TV.
      every thing works great the only problem is the main menu and kodi is not full screen.
      like the picture the main menu is on bottom left.
      alt text
      and kodi starts on upper left.
      alt text
      but when i start a game it's OK and goes full screen.
      alt text
      please help me fix this problem.
      Thanks.
      paradadf 1 Reply Last reply Reply Quote 1
      • ash1390
        plz help me... still need the solution.
        gnubit 1 Reply Last reply Reply Quote 1
        • Shlaf
          Shlaf last edited by Shlaf
          @ash1390 Hi
          I'm new with recalbox but it looks like you just need to change the resolution of Emulation station and kodi in the recalbox.conf file with a specific one.
          Or change the global.videomode line but i'm not sure, can anyone confirm?
          • gnubit
            gnubit @ash1390 last edited by
            @ash1390
            It may be that xorg is not autodetecting the correct resolution of your 2nd display. You can use xrandr to duplicate the image or set a specific resolution on the vga port.
            Common display names are:
            LVDS - Laptop Screen
            HDMI - High-Definition Multimedia Interface
            DVI - Digital Visual Interface
            DP - DisplayPort
            VGA - Video Graphics Array
            TV - Composite Video
            S-video - S-Video
            Get root access: https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
            run xrandr from terminal to see what your displays are: (my example laptop)
            ~ $ xrandr
            VGA-0 connected 1280x1024+0+0 (normal left inverted right x axis y axis) 340mm x 270mm
            1280x1024 75.02+ 60.02
            1024x768 75.03 70.07 60.00
            800x600 75.00 72.19 60.32 56.25
            640x480 75.00 72.81 59.94
            LVDS-0 connected primary 1440x900+0+0 (normal left inverted right x axis y axis) 367mm x 230mm
            1440x900 59.94+
            HDMI-0 disconnected (normal left inverted right x axis y axis)
            Once you know what your display names are you can use xrandr to set your display.
            See the example displays I used with my laptop with a monitor connected via VGA, your display name may be different.
            xrandr --output LVDS-0 --auto --output VGA-0 --auto --same-as LVDS-0 (this will duplicate the same resolution on the VGA port)
            To set a specific resolution on the vga port (eg: 720 resolution)
            xrandr --output VGA-0 --mode 1280x720
            A more complete command that will duplicate the display and set set VGA to 720:
            xrandr --output VGA-0 --mode 1280x720 --same-as LVDS-0
            You could also switch off the laptops display if you want:
            xrandr --output LVDS-0 --off
            Or have the laptop screen off and VGA screen on:
            xrandr --output LVDS-0 --off --output VGA-0 --mode 1280x720
            Once you happy with it you can make it permanent by adding it ~/.xinitrc
            https://github.com/recalbox/recalbox-os/wiki/Change-display-resolution-on-x86---x86_64)
            My apologies for waffling on, hope it may help 🙂
            Sources:
            https://wiki.archlinux.org/index.php/Xrandr
            https://wiki.archlinux.org/index.php/multihead
            seba carp 1 Reply Last reply Reply Quote 1
            • gnubit
              gnubit last edited by
              Apologies the correct wiki link is Change display resolution on x86 x86_64
              • ash1390
                thanks alot for helping.
                seba carp 1 Reply Last reply Reply Quote 0
                  paradadf Staff @ash1390 last edited by
                  @ash1390 what about changing/adding the parameter in recalbox.conf:
                  kodi.videomode=default
                  • gnubit
                    @ash1390 said in Menu and Kodi is not full screen on old netbook:
                    So what worked for you in the end ?
                    • seba carp
                      seba carp @gnubit last edited by
                      @gnubit hi gnubit a mi me sale asi , y se me ve como a el
                      #!/bin/sh
                      matchbox-window-manager -use_titlebar no -use_desktop_mode no -use_lowlight no &
                      set the keyboard
                      systemsetting="python /usr/lib/python2.7/site-packages/configgen/settings/recalboxSettings.pyc"
                      settings_lang="$systemsetting -command load -key system.language"
                      not always true (en_US for us), but it's really better than always english
                      map_name=$(echo $settings_lang | cut -c 1-2)
                      setxkbmap "${map_name}"
                      disable dpms to prevent screen to turns blank
                      xset -dpms
                      xset s off
                      to disable a video output (multi-screen setup) and prevent ES to be stretcht on all screens,
                      uncomment the line below, and replace output_name by the output that you want disable on ES startup (ex: HDMI-0)
                      xrandr --output output_name --off
                      auto hide cursor each 5 sec of inactivity
                      hhpc -i 5 &
                      export HOME=/recalbox/share/system
                      export LC_ALL="${settings_lang}.UTF-8"
                      without windowed, time must be sleeped to wait that matchbox ended to initialize 😞
                      exec emulationstation --windowed
                      gnubit 1 Reply Last reply Reply Quote 0
                      • seba carp
                        seba carp @ash1390 last edited by
                        @ash1390 hola pudiste solucionarlo
                        • gnubit
                          gnubit @seba carp last edited by
                          @seba-carp
                          Hello sebra-carp , sorry but I don`t speak spanish, but looking at your post @ZING referred you here.
                          Have you tried ?
                          xrandr -s 1280x720
                          • seba carp
                            seba carp @gnubit last edited by seba carp
                            @gnubit la unica solucion que encontre fue esta . Pero cada ves que entramos hay que ir a kodi y salir...y queda dicha resolucion..mi maxima resolucion es 1680x1050
