    find old build?
    find old build
    2568
    • leprive
      leprive last edited by
      I have trouble with the 18.04.20 version which I did not have before.
      In ordre to trouble shoot I would like to reinstall 18.03.30 but can't find it to Download. DO you know where I can get it?
      Thks
        HELLO @leprive
        it s not possible
        • leprive
          Oh yeah?
          This is sad. It could be really of use to diagnose issues.
          I'm pretty sure 4.20 has a problem on x86 64 bits. Tried several fresh installs on differents usb sticks.
          I'm sure that many people still have it somewhere on their HD (d**n, I deleted mine a week ago...). If someone has it (the x86 64 bits version) and has ways to make it available for me to DL, I'm really happy.
          Thanks
            paradadf Staff @leprive last edited by
            @leprive there is no version 4.20
            leprive 1 Reply Last reply Reply Quote 0
            • leprive
              leprive @paradadf last edited by
              @paradadf 18.04.20 I assumed removing the common prefix was clear enough.
              sorry
                OyyoDams Staff @leprive last edited by
                @leprive btw, what issues do you have ?
                • leprive
                  leprive last edited by leprive
                  I'm on my pc using usb bootable key.
                  I have :
                  • in the menu, sometimes it would hang for few seconds (no possibility to go up or down or push any button).
                  • some times i press a button or a direction on the pad nad it crashes and displays a black screen with "Loading REcalbox" which never ends.
                  I never had that with the previsou version. I tried two different usb keys with fresh install on two different computers.
                  The problem seem similar to that guys
                  https://forum.recalbox.com/topic/13944/x64-system-running-18-04-20-doesn-t-work-too-well/38
                  Thanks
                  PS: if anyone has a imange for 18.03.36 I can do some report to double check and be sure of what I'm reporting on 18.04.20
