    Lag on HDMI HD lcd screen
    GamePad/GPIO/USB encoder
    lag hdmi lcd
    4207
    • Pegoncology
      Pegoncology last edited by
      Hello.
      I'm a long time Recalbox user. I have now a GBPi3 which is perfectly running excepting the screen that has some lag on menu and games (not video)
      Here we see it on the "rainbows" on the menu
      [https://drive.google.com/open?id=1BEZMH2Wf7ZiiUhFDOojgSgKUQav8YYVs]
      And there when lightnings (3 obliques lines)
      [https://drive.google.com/open?id=1p4Xuf9-eT17Iv1SLkSR4nQqWPVl4OByh]
      Can anyone help ?
      I found this, would it be usefull ? https://github.com/recalbox/recalbox-os/wiki/TFT5-Screen-HDMI-(EN)
      Thanks
        Substring @Pegoncology last edited by
        @pegoncology can you tell which screen you have ?
        • Pegoncology
          @Substring thanks
          It is a 3.5 inch hdmi liquid crystal (new model)
          https://m.banggood.com/35-Inch-480x32060Fps-HD-LCD-Touch-Screen-For-Raspberry-Pi-3-Model-B-2B-Zero-p-1158277.html?rmmds=detail-left-hotproducts__3&cur_warehouse=CN
            @pegoncology can you paste your config.txt ?
            Fbcp wouldn't help, it's for spi tft screens
            • Pegoncology
              @Substring
              Thanks for helping
              "HD" games are running smoothly (PS1, DC, PSP), it occurs into ES menus and with SNES and MD for example.
              Here is my config.txt
              uncomment if you get no picture on HDMI for a default "safe" mode
              #hdmi_safe=1
              disable_overscan=1
              uncomment to force a specific HDMI mode (this will force VGA)
              #hdmi_group=1
              #hdmi_mode=1
              comment to get jack audio
              hdmi_drive=2
              Using /etc/modules is deprecated and no longer supported on 4.4 kernel
              So manually enable audio
              dtparam=audio=on
              config_hdmi_boost=0
              force hdmi while the tv can take time before sending the signal on the hdmi output
              hdmi_force_hotplug=1
              uncomment for composite PAL
              #sdtv_mode=2
              uncomment for lirc-rpi
              #dtoverlay=lirc-rpi
              if you plug your tv at the same time as your rpi and that the rpi switches from the hdmi or give a low resolution because tv had no enough time to initialize it
              boot_delay=3
              uncomment if you don't want the rainbow at startup
              disable_splash=1
              Overclock
              gpu_mem_256=128
              gpu_mem_512=256
              gpu_mem_1024=512
              avoid_safe_mode=1
              kernel=zImage
                @pegoncology can you get the supported HDMI modes using tvservice ?
                • Pegoncology
                  @Substring
                  I don't understand your question, what do you mean ? (You may tell in French, I posted here to have more advices but I'm French-native too ;-))
                  I use this image on a GBPi3, it is exactly the same image I use on my Nespi on TV without any problem.
                  So I assume the problem is with the GBPi3 screen
                  • ian57
                    ian57 Staff last edited by
                    @Pegoncology you should have post your question in french in the french section. Don't forget that the devel team is mostly french ;)... so the support can ben in french too 😉
                    anyway, @Substring is asking to run the tvservice command on you Pi to see the detected video mode :
                    # tvservice -a -s
                    state 0x12000a [HDMI DMT (35) RGB full 5:4], 1280x1024 @ 60.00Hz, progressive
                         PCM supported: Max channels: 2, Max samplerate:  48kHz, Max samplesize 24 bits.
                    • Pegoncology
                      This post is deleted!
                      • Pegoncology
                        Pegoncology last edited by Pegoncology
                        @ian57 @Substring
                        state 0x12000a [HDMI CEA (4) RGB lim 16:9], 1280x720 @ 60.00Hz, progressive
                          @pegoncology i'd rather have tvservice -m CEA and tvservice -m DMT
                          • Pegoncology
                            @Substring
                            tvservice -m CEA =
                            Group CEA has 15 modes:
                            mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
                            mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
                            mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
                            (prefer) mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
                            mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
                            mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
                            mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
                            (native) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
                            mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
                            mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
                            mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
                            mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced
                            mode 21: 720x576 @ 50Hz 4:3, clock:27MHz x2 interlaced
                            (native) mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
                            mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive
                            tvservice -m DMT =
                            Group DMT has 14 modes:
                            mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
                            mode 5: 640x480 @ 72Hz 4:3, clock:31MHz progressive
                            mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
                            mode 8: 800x600 @ 56Hz 4:3, clock:36MHz progressive
                            mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
                            mode 10: 800x600 @ 72Hz 4:3, clock:50MHz progressive
                            mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
                            mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
                            mode 17: 1024x768 @ 70Hz 4:3, clock:75MHz progressive
                            mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
                            mode 36: 1280x1024 @ 75Hz 5:4, clock:135MHz progressive
                            mode 47: 1440x900 @ 60Hz 16:10, clock:106MHz progressive
                            mode 48: 1440x900 @ 75Hz 16:10, clock:136MHz progressive
                            mode 49: 1440x900 @ 85Hz 16:10, clock:157MHz progressive
                              @pegoncology Can you enable DrwFPS and make sure all runs at 60FPS ?
                              • Pegoncology
                                @Substring
                                I have to put this :
                                bool name="DrawFramerate" value="false" to "true" into es_settings.cfg ?
                                  @pegoncology no, you can do it from the ES menu, in advanced settings i think
                                  • Pegoncology
                                    @Substring
                                    It is well running at 60fps but I didn't find DrwFPS into ES menu
                                      @pegoncology paramètres avancés > afficher le framerate
                                      pan pan q q !
                                      • Pegoncology
                                        @Substring
                                        Yes sorry, that's what I did. It shows well 60fps.
                                        But when on ES menu, if I change system and if it is the "first" time I go to the system page, it shows around 40fps then it goes to 60fps in 1 sec. Afterwards I go back to this system and it is well 60fps
                                          @pegoncology it's not stable on more powerful boards, don't worry
                                          now for your screen ... too bad, i'd say 😕
                                          • Pegoncology
                                            @Substring
                                            The builder told me we should wait for firmware update but indeed too bad...
