    Solved Recalbox 18.03.30 does not update to 18.04.20
    recalbox 18.03.30 does update 18.04.20
    2714
    • rastamannu
      rastamannu last edited by
      Hello everyone,
      I am running a 18.03.30 on my Raspberry Pi 3b and now I get a notification that a new version (18.04.20) is available.
      Wenn I start the update, the new version seems to download just fine (244 MB as far as I remember).
      After that the system is restarted to install the new version.
      This however seems to fail;
      the system boots to the Recalbox Intro Screen, then suddenly reboots again and loads the
      old version 18.03.30.
      I have about 16 Gig free space on my card, so that should not be an issue.
      Is there an update log file I can check if there are any errors? How can I help to identify the problem?
      I tried to find if there are other people who have this issue, but unfortunally was not able to find a similar problem.
      Thanks!
      Stefan
        Substring @rastamannu last edited by
        @rastamannu please make a support archive
        • rastamannu
          Thank you!
          Support file was uploaded to
          https://www84.zippyshare.com/v/QyFW7wZz/file.html
            OyyoDams Staff @rastamannu last edited by
            @rastamannu your file system is corrupted on your SD card:
            [   18.946111] EXT4-fs (mmcblk0p2): Couldn't remount RDWR because of unprocessed orphan inode list.  Please umount/remount instead
            [   18.954178] EXT4-fs (mmcblk0p2): re-mounted. Opts: errors=remount-ro,data=ordered
            [  301.307175] EXT4-fs (mmcblk0p2): error count since last fsck: 12
            [  301.307204] EXT4-fs (mmcblk0p2): initial error at time 315536411: ext4_lookup:1584: inode 33528
            [  301.307216] EXT4-fs (mmcblk0p2): last error at time 1519757637: ext4_lookup:1584: inode 79667
            What kind of SD card do you have ?
            rastamannu 1 Reply Last reply Reply Quote 0
            • rastamannu
              rastamannu @OyyoDams last edited by rastamannu
              @oyyodams Its a Transcend Extreme-Speed Micro SDHC 32GB Class 10 card.
              That's quite strange; everything else seems to work just fine. Could this be caused by overwriting the card with Etcher? I had a 4.x Dev Branch on it before that was no longer updateable so I've decided to reinstall.
              Do you think this could be fixed by a manual umount / fscheck?
                @rastamannu you can try, but you should consider to buy a Sandisk class 10 😉
                • rastamannu
                  Thank you for your help!
                  Fixed with a manual fscheck; system updated to 18.04.20 successfully and seems to be stable.
                  I'll keep an eye on the sdcard, but for now everything looks fine.
                  Thread can be closed, have a nice evening everyone!
